Full wave rectifier - diode voltage and current
Dritech
Joined Sep 21, 2011
907
Hi all,
For a circuit as the one shown below, how can I calculate the parameters of the diodes and the load?
Does anyone know of any tutorial which include calculations for determining there ratings?
Thanks in advance.
22,111
Are you looking to calculate Absolute Maximum Ratings, or are you more interested in typical ratings?
I'm not sure which ratings you think are calculated as opposed to measured.
In any case you want to have an adjustable AC source and an adjustable load. Then you want to have two more meters connected as ammeters.
Now you can construct a set of characteristic curves describing the voltage and current as you vary either the AC source, or the load. It is tedious, but instructive work.
For example:
  1. Set the RMS AC source voltage at 30VAC
  2. Set the load at 60Ω
  3. Measure the RMS AC current
  4. Measure the Peak AC voltage across the load
  5. Measure the Peak AC current across the load
  6. Change the the load
  7. Go back to step 3, n times
Plot the data.
From this data you should be able to tell the forward voltage drop of the diodes at various current levels.
With a scope you might be able to see the reverse recovery time.
One time only you might be able to find the maximum reverse blocking voltage
You get the idea.
Dritech
Joined Sep 21, 2011
907
For example:
Plot the data.
You get the idea.
Thanks for the reply. If the Load is 10ohms, what will be the current on the resistor? When using an ammeter in simulation, I am getting 338mA.
18,155
Dodgydave has probably given you all you need. I'll just add that a diode is not ideal - its properties change with current level and temperature, which are in turn related to each other. So if you need precision, things get more complicated. Also, the 4.78V AC noted by Dave is the RMS voltage. The peak-to-peak voltage is higher. You would see this if you were to add a filter capacitor to the DC side of the rectifier.
22,111
Adding the capacitor will make any DC measurements easier to make, but may impede your ability to characterize the diodes in the bridge rectifier. I was thinking that you wanted a complete set of IV curves for the diodes, rather than just the solution to a particular setup.
Dritech
Joined Sep 21, 2011
907
Thanks for the replies. I had a mistake in the simulation, that's why I was getting 338mA when the load was 10ohms and the input supply was 240VAC RMS. Now I am getting 33A. 33A*10ohms = 330V + 2.2V of the diode. This is far higher than the 240VAC of the main supply. What can be wrong?
Also, for a diode that can handle 33A, what parameter should I look for?
(Note: this is only for simulation and it will be not implemented)
