I'm a little new, so bear with me please:
I'm currently trying to create a full wave rectifier to convert the output from an AC power supply to run into a DC electronic load I have. I'm trying to run the power supply at full current/voltage which is roughly 4.7 AAC and 190 VAC. I'm trying to pick the right components for the rectifier, but am a little confused to diode specs because I want to be very careful not to blow up any components, and the store I'm going to has very little diode specification information online.
First off, would it be wise to buy around a 200 V diode at 5 watts? I am trying to calculate the max power, but I can't tell if the diode drop is just going to be 200 V, in which case the would the power dissipation be P = I*V = 4.7*200 = 940? Or is this voltage rating the max voltage allowed to run over the diode?
Second, if that is the case and I need to attenuate my AC signal a little bit (keep in mind I'm just trying to run full power out of the power supply for experimentation sake so I may run it through the electronic load) is it possible for me to decrease the amplitude with an RC filter using high wattage resistors and a high voltage cap, then run it through a rectifier, and then run the DC signal through the DC electronic load I have?
Sorry if this is written in a confusing way.
