Hello.
So, along with the LEDs thing, I'm also trying to design and build a full bridge rectifier with voltage regulation.
I already have a circuit and I just want some insights to understand if it is good enough for simple applications (home made) or if anything else is needed.
This is what I have in falstad online simulator!
The input is 230V, 50Hz (EU mains). The output is set to about 10V by the 240Ω and the 1.7kΩ resistors!
I attached the txt file so that anyone that wants to open it in the online simulator, can do so.
The datasheet I used is here (page 13):
https://www.ti.com/lit/ds/symlink/lm317.pdf
Note: That 10Ω resistor is just because falstad doesn't allow capacitor loops without resistance. So, I added that resistor!
