full bridge inverter using BJTs
Sami Ullah 5
Joined Dec 27, 2018
First of all is it ok? to use Bjts (2n222) in an inverter rather than Mosfets
secondly i have designed a circuit i i'm having trouble with the ratings of resistors , plus the circuit is operating accordingly when both the voltages(the voltage to be inverted 5v and the source voltage of the 555 is 5v ) but as i change the voltage to be inverted to 12v keeping the 555's supply at 5 the inversion is not as according to the principle ,is it need to keep both the voltages same?inverter.png
AlbertHall
Joined Jun 4, 2014
12,653
If the '555 is operating with a 5V supply, but the '7404 is running on a higher supply voltage then the output from the '555 (max 5V) will not cross the input threshold of the 7404.
bertus
Joined Apr 5, 2008
23,013
The 7404 is a TTL chip. It has a supply voltage range of 4.75 to 5.25 Volts.
Running it at a highr voltage will damage the chip.
Bertus
BobTPH
Joined Jun 5, 2013
11,662
If there were no other issues, you would get about 2-3V out of that bridge. You need PNP transistors for the high-side switches. That will get you up to about 4V. MOSFETs would bring it close to 5V, which is why they are preferred.
Bob
