Hello everyone
I'm looking to implement an FSK demodulator, I did some research regarding FSK modulation and demodulation and I understood that essentially the concept of working is quite simple.
Where a digital 1 translates to a high frequency, and a 0 translates to a low frequency.
Taking a look at the available demodulation circuits, they all seem quite complex and not really explained furthermore, not many variations of the demodulator exist...
What I wanted to ask was whether a simpler approach would work, using a filter followed by a comparator...
since we know the frequencies which represent a digital 0 and 1, we can expect the filter's voltage output (response) to each frequency. Now we compare these voltages to a reference.. if it's higher than the reference we output a 1, else if it's lower we output a 0.
The issue which comes to my mind is... in the comparator what would be the reference? Furthermore, our input is an AC signal and in a comparator we would need to compare it to an AC signal as well right?
That's all for now
Thank you
That's all for now
Thank you
