Hi Guyz,
Most of you guyz know I been using PIC16F690 since i started playing with Pics uC but now I'm shifting to PIC18F26K20 (16MIPS, 3.8Kb RAM,...)
Attached is my usual template that i been using...
Now i want to know about the major changes I'll have to make about this template!?
Have a look especially at the 'variable definition section', the 'interrupt processing section', the 'config fuse section', and 'header file section'...the rest is easy to change!
In the meantime I'm quickly scrolling through the datasheet to get familiar with this PiC18F...(you can also tell me where i need to put emphasis on...)
Also where (provide links) can I order a 64Mhx Crystal for this PIC18F26K20
Will talk about the big function is next post!!
regards, Eric
regards, Eric
