Timer 2 PIC16F690
Cosmyn99
Joined Jan 8, 2022
I am sorry to bother you, but after some days staring at this problem I wanted to ask for help.
I have some homework, most of wich I have already done, but the I got to the timer part and I have no ideea how to solve this.
So I want to ask for some experts help.
Task: Generate a PWM signal, with 8Hz frequency and duty cycle of 20%, connected on output led(pin DS3/RC2), with the help of timer2 register.
I have no ideea where to begin with this.
Thank you for all of you time.
JohnInTX
Joined Jun 26, 2012
4,787
Have you read chapter 11 in the databook? It describes in detail the PWM and how to generate an output using TIMER 2 as the time base.
Ian Rogers
Joined Dec 12, 2012
1,136
Yes! He means chapter 11.3 of the datasheet...
8 hz isn't very fast do you mean 8Khz.. Timer two only has 1:1 , 1:4 and 1;16 prescalers.
All you need to do is set the timer pre-scale set the PR2 register and the timer post scaler and switch it on.
Cosmyn99
Joined Jan 8, 2022
I read that chapter of the datasheet, but I dont get how to do the setup. The frequency is 8Hz
sagor
Joined Mar 10, 2019
1,049
What clock frequency is the PIC running at? No one can calculate the PWM values without knowing the clock.
For standard 4Mhz or higher, there is no "standard" PWM solution for 8Hz. If running at a low clock like 32Khz, you can get 8Hz with:
Code:
 * PWM registers configuration
 * Fosc = 32000 Hz
 * Fpwm = 8.00 Hz (Requested : 8 Hz)
 * Duty Cycle = 20 %
 * Resolution is 10 bits
 * Prescaler is 4
 * Ensure that your PWM pin is configured as digital output
 * see more details on http://www.micro-examples.com/
 * this source code is provided 'as is',
 * use it at your own risks
PR2 = 0b11111001 ;
T2CON = 0b00000101 ;
CCPR1L = 0b00110001 ;
CCP1CON = 0b00111100 ;
See online PWM calculators:
https://www.micro-examples.com/public/microex-navig/doc/097-pwm-calculator.html
sagor
Joined Mar 10, 2019
1,049
Other possible solution is to set interrupt with Timer2 at a higher rate, like 40Hz, and count the timer intervals and turn on the output 20% of the time, then wait until 125ms is up and restart the cycle count. Still, interrupt rate is dependent on clock rate...
Ian Rogers
Joined Dec 12, 2012
1,136
I would do the same...
estimate a resolution say 8 bit...
Set a duty between 0 ~ 255 . F
Set a pin low.
Fire the timer every 488uS and count each interrupt to 255 comparing against the duty
when its equal set the pin high...
Repeat..
