From breadboard to schematic
brandon jr
Joined Nov 26, 2017
2
I am having trouble drawing this schematic. I think r2 and r3 are in parallel but i dont know if i am right and i know if i draw it wrong my calculations will be wrong
32,854
What is required for two resistors to be in parallel? Do R2 and R3 meet those requirements? If so, they are in parallel?
Another easy to miss subtle point: What is the voltage difference across this resistor network?
Take your best shot at drawing a schematic and show it. Then we can give you feedback to figure out if and where you made a mistake.
brandon jr
Joined Nov 26, 2017
2
This is what i have drawn so far
absf
Joined Dec 29, 2010
1,968
Is this really homework?
Don't you need to calculate anything like the total resistance or voltage or current flowing through each resistor?
tranzz4md
Joined Apr 10, 2015
315
Yup. No difference.
Turn your b-b or your "schematic" 90° and they'll match each other exactly. I draw horizontal rungs primarily anyhow.
32,854
MOD NOTE: Doesn't it seem at least remotely possible that since the problem gives the color bands, that part of the assignment is for the TS to determine the resistor values based on that information? Let's give the TS the opportunity to exercise his skills in that regard and let us know what THEY determine them to be. THEN we can confirm/correct what they tell us.
EDIT: The posts in question have been deleted, but the point is still worth making note of.
32,854
We haven't been given any indication that this is a problem area for them. If it is, let's see how it is a problem so that we can help correct it. By supplying all three resistor values, the TS doesn't even have to attempt to figure out any of them, and so if they do have problems doing so, they won't get to have that pointed out.
