They can cross, any connection can connect to anywhere else, including a bunch of internal nodes for measurement or routable GPIO or power supplies. There's some theoretical limits but they're pretty hard to hit, the routing algorithm can usually find a path even if that means making some intermediate hops.Presumably they cannot cross
There's not really a current limit, just a voltage limit + crossbar resistance, so 9V / ~45Ω = 200mA. Or if you were somehow dropping +9V to -9V you can push 400mA, it doesn't break them, I've tried it.And there is undoubtedly some resistance inserted and a current limitation.
Fairit is a showroom piece but imho completely useless.
That's actually a good idea. There's no smaller one (well, the V1 / OG, but it's much worse), but I should just add an option to order them with a return label already in the box. Until I add that officially, if you put that in the order notes, I'll do it. Just order from me directly because Mouser will make that a nightmare.Well they do look impressive but what has been echoed on here is that hands on trial part. maybe if they sold small versions of this to trial the tech then order the bigger ones if the small ones fit the bill. Standing on the outside and lacking the hands on part they do look impressive and a huge time saver assuming they work as advertised.
Well now about the small boards at a reasonable price for us to look into and allow us to play, the thing we all love to do. This would cement your tech and your place in the breadboard choices. Next would be how big a breadboard can you get and the thing no one likes to ask but I love it is. How much, are you able to compete with breadboard choices out there now. Jumpers or not. Or can you at least justify the extra cost into a time saving formula. this is what matters to me and I'm sure others also.Hey! I'm the guy who makes these (thanks, Google alerts.) I'm happy to answer any questions you have about it.
Here's the schematic, you can kinda trace through how a connection gets from one place to another if you stare at it long enough.
It fills the unused routing space on the board with parallel connections to get lower resistance connections, so that current gets spread out across a few chips. Those CH446Qs can handle more current than they claim.
And that's also kinda handled with policy because I didn't want people being scared to use it.
Fair
The realities of low-ish volume electronics manufacturing would mean an even smaller 1/4 size Jumperless would still be like ~80% of the cost, and be pretty useless. As for making larger ones, the cost would go up faster than just simple 2x cost for 2x breadboard area for a bunch of reasons. The more efficient way is to just get 2 and connect the the Nano headers together and route stuff through them.Well now about the small boards at a reasonable price for us to look into and allow us to play, the thing we all love to do. This would cement your tech and your place in the breadboard choices.
Well, it's not really meant to compete with a $6 breadboard or those 3M things where they bolt a couple breadboards to a piece of plexiglass and charge absolutely ridiculous prices. It's more a weird electronics multitool in a breadboard form factor, because that's the de facto standard things fit into.How much, are you able to compete with breadboard choices out there now. Jumpers or not. Or can you at least justify the extra cost into a time saving formula. this is what matters to me and I'm sure others also.
What kind of bandwidth do the connections offer? is there any degree of crosstalk (like capacitive) between distinct connection? do you have the ability to generate a PCB design from a connection netlist?The realities of low-ish volume electronics manufacturing would mean an even smaller 1/4 size Jumperless would still be like ~80% of the cost, and be pretty useless. As for making larger ones, the cost would go up faster than just simple 2x cost for 2x breadboard area for a bunch of reasons. The more efficient way is to just get 2 and connect the the Nano headers together and route stuff through them.
I don't know what your time is worth or what your workflow looks like, but I use them all the time and find it pretty handy. But no, it would be hard to justify mathematically against regular breadboards. It's still a bit of a boutique item and hopefully someone starts cranking them out in China for super cheap (it's open source and I really want someone to do this, no takers so far.)
i appreciate feedback that they will not blow up. this is not what i expected..There's not really a current limit, just a voltage limit + crossbar resistance, so 9V / ~45Ω = 200mA. Or if you were somehow dropping +9V to -9V you can push 400mA, it doesn't break them, I've tried it.
Someone with much better equipment than me tested this. https://codeberg.org/multiplex/jumperless-wigglyvoltsWhat kind of bandwidth do the connections offer? is there any degree of crosstalk (like capacitive) between distinct connection?
Isolation is -84dB for unconnected rows, but really a lot of this just comes down to the fact that a breadboard is basically a bunch of crappy capacitors.The TL;DR is just the physical breadboard puts the 3dB roll-off at ~13MHz, and a signal passing through the crossbar matrix brings it down to around ~8MHz.
It makes sense these are pretty high, these CH446Qs were originally made for switching video signals so bandwidth was pretty important when they were designing them. Keep in mind this isn't a hard limit, it's just where the signal gets attenuated by the (arbitrarilyish) defined 3dB, so your signal's amplitude is reduced by √2.
connect(GPIO_1, 15)
freq=1000
while freq <= 62000000:
pwm(GPIO_1, freq)
time.sleep(0.01)
freq += 1000
If you're in the universe of worrying about how many inches of wire your signal is going through, a breadboard (Jumperless or not) is gonna be complete garbage. But like 12.5MHz SPI or USB or any signal you'd typically see on a breadboard gets through just fine, I haven't tested the crazy fast things like LVDS or HDMI but I'd be super interested for someone to try it and let me know.I guess I'm asking what limitations to signal flow are there compared to say a 3" piece of copper wire.
Yeah that's where it really gets interesting. It has a whole-ass MicroPython interpreter onboard so you can just put down the parts you're interested in and then have the Jumperless set the clock and address bits for example. Or have it read the state of your circuit at different times and store it in a file.I think its a very neat idea, unlike physical breadboard, connections can change in real-time, to achieve that on an ordinary breadboard requires actual circuit logic, so it can in some ways, simulate logic design.
I could do that, but I never will on principle. Any auto generated PCB looks like complete garbage, there just isn't the information in a netlist to do that well. And laying out PCBs is the fun part. But yeah you can export the netlist in a variety of formats and do whatever you want with them, I just don't want to encourage that particular style of laziness in EE. Not to be a snob, I just think it costs beginners way more time than it saves in the long run.do you have the ability to generate a PCB design from a connection netlist?
It still trips me out that this works, but turns out putting 220Ω resistors in series with the Vdd and Vee lines of the crossbars helps a ton. Not that they'll never blow up, it still happens in weird situations. But it takes like 10 seconds to replace those QFPs with a hot air gun. If people are worried or know they'll be pushing limits, they can ask for a bag of spare CH446Qs in the box.i appreciate feedback that they will not blow up. this is not what i expected..
so kudos on the design and making it open source (i was impressed with documentation and instructions)
The Jumperless V5 is basically a programmable breadboard that lets you create and change circuit connections through software instead of manually moving jumper wires. It looks like a really interesting tool for quick prototyping, testing ideas, and experimenting with electronics.
It strikes me as ideal for schools, colleges - perhaps he can get some big contract, make some serious dosh! The only unattractive aspect of the device is that it needs a PC or something on which to define the wiring layout, but it does give you a lot in return.The Jumperless V5 is basically a programmable breadboard that lets you create and change circuit connections through software instead of manually moving jumper wires. It looks like a really interesting tool for quick prototyping, testing ideas, and experimenting with electronics.
The biggest advantage seems to be the ability to modify circuits quickly without constantly rewiring everything. It could be very useful for Arduino, microcontroller, sensor, and small electronics projects. However, for simple circuits, a regular breadboard and jumper wires may still be the easier and more affordable option.
It’s a unique concept though almost like having a breadboard that can wire itself.
That’s a good point. A tool like this could be really useful in schools and colleges, especially for electronics, engineering, and STEM programs where students need hands-on experience. If it gains enough attention and proves reliable, educational institutions could definitely be a strong market and potentially lead to some larger contracts. It’s an interesting idea with a lot of potential.It strikes me as ideal for schools, colleges - perhaps he can get some big contract, make some serious dosh!
I also wonder if it could acquire a knowledge of various devices, so if I wanted to wire up some chip, it can see that I'm short circuiting an output maybe or leaving an input floating and so on...That’s a good point. A tool like this could be really useful in schools and colleges, especially for electronics, engineering, and STEM programs where students need hands-on experience. If it gains enough attention and proves reliable, educational institutions could definitely be a strong market and potentially lead to some larger contracts. It’s an interesting idea with a lot of potential.
I see the issue that using a computer opperated breadboard will certainly reduce any hands-on experience! An adequate simulator would be a more efficient experimenting device, as I see it. SO the simulator will really need to be able to ask questions prior to starting the simulation. The closest that I have seen are the PCB layout software design rule checks.That’s a good point. A tool like this could be really useful in schools and colleges, especially for electronics, engineering, and STEM programs where students need hands-on experience. If it gains enough attention and proves reliable, educational institutions could definitely be a strong market and potentially lead to some larger contracts. It’s an interesting idea with a lot of potential.
Yep, it does that. How it works internally is every node has a set of other "do not intersects" where it will just ignore connections to those, soIncidentally @Kevin Cappuccio - does it provide sanity checks? prevent short circuits or pointless wiring (wires that connect places to themselves) etc?
connect(TOP_RAIL, GND) is just a no op (there's a debug flag to tell you if you want.) Of course you could get around it by putting a jumper on the board and connecting either end, unless you took the time to set custom do not intersects on either end.Man, this is so helpful for figuring out what my docs are unclear on. The prime directive of V5 was to make it perfectly useable without a computer, you can do everything with the probe and clickwheel and just plug it in for power. The JumperlOS firmware is so sprawling at this point that it basically is its own computer.The only unattractive aspect of the device is that it needs a PC or something on which to define the wiring layout, but it does give you a lot in return.
Just a fun hack that it does, it can sense the difference between floating and grounded on its GPIO by twiddling pullups. There is some old code for knowing about chips, but now that the python stuff is mature, I figured it's better for users to put that in a script so it's not making any assumptions the user is unaware of. But just having a visual pinout guide might be really cool.it can see that I'm short circuiting an output maybe or leaving an input floating and so on...
| Thread starter | Similar threads | Forum | Replies | Date |
Beyond the Breadboard: Troubleshooting startup glitches on a custom PCB | Microcontrollers | 6 | |
| G | How to breadboard a OPA454AIDDAR-TI_SO-PowerPAD-8_ThermalVias | Analog & Mixed-Signal Design | 5 |
