Frequency Change Detector
meceng
Joined May 9, 2017
I have max 8 MHz sensor signal and I would like to detect the at least 8 Hz frequency change and collect the data. Is there anybody who could suggest me what to use for such high precision? PS. The change in amplitude is not important. Only thing i need is to detect the frequency change. Low power should be considered so I can not use the solutions that requires high power.
38,481
What output do you want for this frequency change?
Do you want to know the amount of change, or just that it has changed?
meceng
Joined May 9, 2017
How about a direct conversion receiver?
Bertus
I do not have knowledge on it so i will check it. Thanks for the suggestion. If you have any source i can get the most accurate information i would love to hear from you.
bertus
Joined Apr 5, 2008
22,917
Here is a link:
https://aa7ee.wordpress.com/tag/direct-conversion-receiver/
When you use a 8Mhz crystal, the output will be round 0 Hz, when the input signal is 8 Mhz.
When the frequency is higher or lower as the crystal frequency, a signal will be outputed.
You can also use an offset, say 8Mhz + 1000 Hz.
When the frequency is exact 8 Mhz, 1000 Hz will be present at the output.
When the frequency is a couple of Hz higher or lower, it will be added or subtracted from the 1000 Hz.
Bertus
Alec_t
Joined Sep 17, 2013
15,116
Any crystal used to establish a reference frequency would need to have a better than 1ppm stability. How quickly is the variable frequency going to change?
ian field
Joined Oct 27, 2012
6,536
Probably not the resolution you need - but there's frequency to voltage chips. You can follow that with a data slicing comparator, you can find examples from old disk drive service manuals. The average input voltage charges up a capacitor via a resistor and provides Vref for the comparator - the input goes directly to the other comparator input. You probably need a cross between that and a window comparator to detect deviations of both directions.
BR-549
Joined Sep 22, 2013
4,931
It kinda depends on how you define your data. If detecting 8 hertz/parts change out of 8 million......is all you need......I believe one could do it with low power. Even come close to quantifying the change.
But if you have to precisely measure the frequency that close.....then no......not with low power.
AnalogKid
Joined Aug 1, 2013
12,114
Whether it is a direct conversion circuit (very cute) or a frequency counter, you are trying to resolve a frequency change of 1 part per million. To do that you will need a frequency reference (crystal oscillator, etc.) with better precision than that. That is expensive. In ascending order of price, a double-oven crystal oscillator, a GPS-disciplined oscillator, a rubidium standard. The last two output 10 MHz, so this would have to be divided or phase locked down to 8 MHz for the receiver, or up to 100 MHz for a frequency counter.
Or something like that.
ak
38,481
Is the frequency accurate to a few Hz absolute, or is it approximately 8MHz and you just want to detect a deviation from whatever value it is?
How fast does this deviation occur?
BR-549
Joined Sep 22, 2013
4,931
Don't some some of these ultra low power and super fast controllers run at and above 80 MHz now. Some even higher.
And don't most have built in high precision and stable oscillators now? Not at 1 ppm of course...but still....low rates of drift? Run time counters are common also.
With these clock rates and slow drift.....can't we make some RELATIVE measurements at 8 MHz?
The oven of course....kills low power.
Alec_t
Joined Sep 17, 2013
15,116
@Alec_t , So would a reference for a frequencymeter also be, as @R!f@@ suggested.
As I see it, to resolve 8Hz in 8MHz, however you do it, implies a crystal (or other) reference frequency accurate (or stable) to better than 1 ppm, at least in the short term: but if both the DUT and the reference frequency were to drift in sympathy in the long term it should be possible to detect a short-term frequency shift. That is why I asked how quickly the DUT frequency was likely to change.
