Frequency Alignment of Signal Generator W/ Oscilloscope
SamR
Joined Mar 19, 2019
5,535
This is actually an Oscilloscope Input question. I have rebuilt a Heathkit IG-102 RF signal generator. It is surprisingly well aligned after replacing all of its electrolytic caps and replacing the 2-wire cordset with a modern grounded 3-wire cordset and safety caps. The question is, using BNC connectors and 50Ω impedance coax to connect the output to the oscilloscope I have 2 input options. Set the input for 50Ω or 1MΩ impedance. Which should it be set to? At the 1MΩ the current in will generate a greater voltage signal? In this case, I am simply looking to get the highest peak waveform @ the correct frequency by adjusting the tuning slugs in the RF generator. @tautech
tautech
Joined Oct 8, 2019
507
If your RF Sig gen can provide over 5V output use the 1M input or the scopes 50 Ohm input may be damaged.
Alternatively terminate it into a 50 Ohm feedthrough so to provide a balanced feedline then into the 1M input.
SamR
Joined Mar 19, 2019
5,535
Nope, signal in in the ~10mV output range. So use 50Ω unless signal >5V?
Are you saying use a BNC tee with a 50Ω terminator at the scope input?
Thanks, Sam
tautech
Joined Oct 8, 2019
507
You mean a direct coax connect without any other fittings then?
A proper RF gen expects a 50 Ohm load and the amplitude adjustment on your old one is probably set up for that.
Into HiZ the signal amplitude is probably 2x the generators settings unless it has a 50 Ohm and HiZ output setting.
