Since this is a Fourier Analysis problem, his is probably expected to arrive at a solution using Fourier Analysis. My guess is that he has just covered Parseval's Theorem in class.you can create same circuit (with Sine wave voltage sources) in any spice simulations tools like LTSpice/TINA-Ti and check it easily yourself.
Definitions that occur to me are "RMS", "peak", "peak-to-peak" and "average". I include all those just for completeness although I don't see how some of them could be used in this problem. Are there others in common use?What is the definition of "magnitude" that your text is using?
The only way I can think of is for peak-to-peak, since that ignores the DC component. But that doesn't seem to be a reasonable interpretation for this problem.Definitions that occur to me are "RMS", "peak", "peak-to-peak" and "average". I include all those just for completeness although I don't see how some of them could be used in this problem. Are there others in common use?
I ask because I don't get any of the four answers. There is a constant term of 10 in the function. How could the magnitude of the overall function be less than 10 for any reasonable definition of magnitude?
