$$R_{balance} = \frac{NV_{rate} - V_{bus}}{I_{maxleak}}$$
N is the number of capacitors in series
Vrate is the rated maximum voltage for any one capacitor
Vbus is the bus voltage (the expected voltage across the whole series of capacitors)
Imaxleak is the maximum leakage current
Rbalance is the value of the balance resister between any two capacitors
Source: https://va1der.ca/index.php/balance-resistors-for-series-capacitors/
Above equation is used for the calculation of balance resistor values used for capacitors in series with higher supply voltage than capacitor ratings.
How this formula is obtained or derived from V=IR standard formula?
