Fm transmitter and receiver
mussa
Joined Jun 10, 2019
45
So, using FM Radio Transmitter Module V2.0 i create an Fm radio station broadcasting music or whatever else and i used tea5767 fm receiver to receive to music, but the problem is on some frequency the local station signal interfere with my broadcast sometimes stronger. I thought of a way that might help solve this but i need help in programming, the idea is to create a function/ a header on both sides transmitter and receiver make the receiver scan that first and only receive from my transmitter ignoring the other station.
Ylli
Joined Nov 13, 2015
1,092
Disregarding the legality of your transmitter, why don't you just pick a frequency where there is no 'Local Station'?
mussa
Joined Jun 10, 2019
45
it's possible, i also want to be able to use the occupied frequency without any interference it would make project easier
Ya’akov
Joined Jan 27, 2019
10,294
FM (Frequency Modulation) detectors experience an effect called "capture". The stronger signal will simply override the weaker.
First, there are serious legal issues with broadcasting on the FM band, depending on your location. The overwhelming majority of the enforcement actions of the FCC are against pirate radio stations in the FM band.
In any case, the only legitimate way to do what you want is to avoid broadcasting on frequencies assigned to local stations.
Why do you want to use this band?
mussa
Joined Jun 10, 2019
45
i want to create a loop that goes from 88 - 108, but some frequencies are very strong it will interfere. Then is there a way to detect the occupied local frequency and skip them?
Sensacell
Joined Jun 19, 2012
3,787
Make a list of those occupied frequencies, code them as a table.
Skip the ones in the table.
djsfantasi
Joined Apr 11, 2010
9,237
Can you communicate between devices. Can the transmitter also act as a receiver?
Given the latter (and you can figure out how to apply this principle, given the former), you could dynamically build that table.
At power up, scan through your entire range with the receiver, and if a strong signal is received, add that to a skip table.
Then, this table is used to skip frequencies in all future scans.
mussa
Joined Jun 10, 2019
45
transmitter can only transmit, same goes for the receiver only receive.
But how does the receiver distinguish between high and low frequency?
ronsimpson
Joined Oct 7, 2019
4,803
OK. I was thinking about making the signal "a little different" so the receiver could detect it verses normal FM. With data that can work. With music …. You could transmit mono not stereo. The receiver could detect that.
You could add a receiver to the transmitter end. The receiver (at power up) will look for a quite frequency to transmit on.
navyguy
Joined Sep 27, 2019
108
If he lives in Southern California like I do finding an empty frequency is almost impossible. I had my FM transmitter I never could find one
