I'm looking into this reference design: http://www.ti.com/lit/df/tidrlf7/tidrlf7.pdf . See it attached also.
I have three questions:
1) What could be the reflected voltage? I see D1 is 110V, so it leads me to think they chose a low reflected voltage for this wide input range (64-1260VDC). This is what I think:
With two 800 V mosfets, we should leave at least 100V safety margin when at max voltage. So, we don’t want to exceed 700V on each drain, i.e., in total 1.4kV.
Vinmax + Vz = 1400 + Vz <=1200
Vz <=1400 – 1200 = 200V
Let’s pick Vz = 110V
Vz/VOR = 1.4 optimum ratio
VOR =0.7*110 = 77 Is this Okay?
2) How is the voltage shared between the two transistors? Is there a moment when a transistor could get more stress than the other?
3) They don't use bulky capacitors at the rectifier output. Is not ripple an issue then?
