Flyback diode rating
Momentory
Joined Sep 4, 2022
101
I want to understand how to select the diode rates
I found this circuit in YT video i can not found it again
Batteries 400v - Capacitor 450v 1000uf - load 3.6 ohm - diode
This diode is placed to prevent the back emf on the switch
How diode rate is selected for a circuit to prevent back emf?
28,272
The diode will not be needed, because when the button is pressed about 120 amps will flow and thus the wiring will melt as the button evaporates. And if it is in a simulator there will be no arcing because all simulator components are perfect.
Plus, the component L1 has no inductance, only a resistance of 3.6 "m". Possibly short for ohms? or millihenries?
Momentory
Joined Sep 4, 2022
101
I doubt this circuit need a thyristor not just a switch
But the diode should be work as back emf suppression
28,272
That 120+ amps will not flow in the diode, but in the rest of the circuit, until something melts. The caption describes the coil as 3.6 ohms. Amps =400V/3.6 ohms
And the circuit is a good example of what is not to to be trusted on YT.
Momentory
Joined Sep 4, 2022
101
It is push button means this current will pass for few milliseconds, i think nothing will melt as this fast (expect the switch so it need thyristor)
This current will start from capacitor so the second circuit only will get this big current
After the switch open their will be a back emf in this case the diode should do the work
28,272
The voltage developed is inductance multiplied by the rate of current change. Wit 400 volts and over 120 amps there will be an arc as the switch contacts open and thus the rate of change will not be fast.
And if this is a simulation then the voltage source has zero internal resistance and the capacitor has not much effect.
If this is an actual circuit what is the purpose?
Momentory
Joined Sep 4, 2022
101
It was a demonstration circuit
I want to learn how to select a diode ( diode rate) for a circuit like this
I think if we add a diode like 1n4007 which is 1kv and 1A to supress the bemf will not work or damage
28,272
Probably that is true. But given that we have no clue as to how fast the current changes with the non-realistic values, we have no idea as to the voltage or the power associated with that circuit operation. Do those contacts open in a nanosecond?? Or do they take a millisecond to cut off the current??
If a transistor oof some type is used, what is it's time to transition from full conduction down to 10% conduction?? Microseconds or picoseconds? Or milliseconds???The rate of change is what makes the difference.
Ian0
Joined Aug 7, 2020
13,278
The diode must be rated as follows:
Voltage: equivalent to supply voltage
Current: equivalent to load current
AS it does not state how long the switch is closed for, the current is unknown.
Momentory
Joined Sep 4, 2022
101
It is normal open push switch means it will take very few milliseconds, just a press
So diode should be 120A, 400v!
Is there a diode has rate like this?
Ian0
Joined Aug 7, 2020
13,278
