Floppy Diskette Music
Bod
Joined Sep 18, 2016
317
This is a project I had in mind for a while, I was thinking about playing music with a floppy but not like vaser888. I wanted to know if it was possible to put music onto a blank floppy disk then have the drive read the music and play it through an external speaker. Would this be possible with floppies(ys?) or would I need to use CDs?
Thanks
Bod
P.S Hopefully it's not in the wrong forum!
bertus
Joined Apr 5, 2008
22,925
Keep in mind that the floppy has a capacity of 1.44 Mb (double sided 3.5") as the CD has a capacity of 700 Mb.
An audio CD can play max 80 minutes, when WAV is used.
When you would put the WAV format on a floppy, you would be able to store 80 minutes X (700 Mb / 1.44 Mb) = 0.16 minutes.
A well compressed MP3 would give you maybe 10 times longer playtime.
AlbertHall
Joined Jun 4, 2014
12,625
Theoretical maximum transfer rate of 3.5" floppy is 500kbits/S, 62.5kbytes/S, so it would take about 23 seconds to read the entire contents. It would seem to be necessary to read the floppy into a ram buffer and then play the music from the buffer. 23 seconds of 'buffering'?
Bod
Joined Sep 18, 2016
317
Thanks! I didn't mention it but I wasn't going to play one song on one floppy drive I was going to split the music into separate instruments and play those on floppy drives. E.G A guitar chord would be repeated on one floppy disk. The second floppy would have a piano chord. You
get the idea. There would be up to eight floppy drive.
Any idea where I can get working floppy drives for cheap?
Bod
Joined Sep 18, 2016
317
takao21203
Joined Apr 28, 2012
3,702
Thanks
Bod
It is possible but not handy.
Normally use SD Card.
