Floating Ground Battery Conversion to Grounded Battery
jonsnowknowsnothing
Joined Nov 6, 2016
I have got a battery without ground and i am trying to convert it to positive ground. Is it possible to do without discharging battery completely and charing it again?
i have attached picture of what i am trying to accomplish.
jonsnowknowsnothing
Joined Nov 6, 2016
i have got equipment which is working at -48 with return might be grounded to chassis, with due to that i believe my charger is giving positive ground alarm.
AlbertHall
Joined Jun 4, 2014
12,652
If the present system already has a ground connection then you cannot do this without removing the existing ground reference. To do so would result in a short circuit.
jonsnowknowsnothing
Joined Nov 6, 2016
There is no Reference to ground for Battery or Charger. They are floating. Only the Equipment that we will connect to the breaker panel will have Return grounded to Chassis.
