flip flop
WBahn
Joined Mar 31, 2012
33,193
Why do you say that?
I won't play twenty questions so that you can get the answer by guessing.
Show your work (i.e., the internal nodes) and I will gladly either confirm that you are drawing the correct conclusion from it or attempt to guide you toward seeing why your conclusion is wrong.
WBahn
Joined Mar 31, 2012
33,193
Again, I won't play 20 questions. Look at it from our perspective. Here you are refusing to do a simple analysis and show your work. You have two guesses at an answer but don't know which one is correct. You have been told that one of them is correct. So all you have to do is randomly pick one of them and declare it to be your answer. Whether it is correct or not is irrelevant because as soon as someone tells you whether it is correct or not you discover, without ever doing the work, which one is correct.
So, as I said before, I won't comment on the correctness of your work until you actually show some by including the internal nodes in your diagram.
