Flat ribbon cable 8pin
hide24
Joined Jul 9, 2019
84
I'm looking for a flat ribbon cable called SUMITOMO AWM 2896 (8pin) which I can't find anywhere.
Anyone knows where I can purchase it? If not another brand is ok.
Mine is 2,4cm width, and it seems all the cables I found are smaller, or have more pin than this one.
I attach picture
Thank you!
jpanhalt
Joined Jan 18, 2008
11,087
Assuming both ends are the same:
At Digikey they are called FFC FPC "jumper" cables (https://www.digikey.com/products/en/cable-assemblies/flat-flex-jumpers-cables-ffc-fpc/458?k=FPC&k=&pkeyword=FPC&sv=0&pv89=9726&sf=0&FV=-8|458,ii8|2245&quantity=&ColumnSort=0&page=1&pageSize=25)
They also come in various lengths with different ends, e.g.:
Getting one with a 2-mm pitch will be more difficult. I checked JST too and it didn't seem to have them.
EDIT: Ebay lists some: https://www.ebay.com/itm/AXON-FLEXI...265917?hash=item41e6a23b3d:g:ti0AAOSwKZtajbJO
Try searching on just part of the number, like "AWM 2896 flat cable"
hide24
Joined Jul 9, 2019
84
Thank you very much!
Just one question..
I saw in the picture that the cable has a socket installed. This kind of cables also can be used for a LCD displays too?
jpanhalt
Joined Jan 18, 2008
11,087
Yes, such cables can and very often are used to connect LCD displays. Many displays, however, are 2 mm or smaller pitch, not 2.54 mm (0.1"). The one I happen to be using right now is 0.5 mm pitch.
