Flashing 3 pin LED
SanctuCaryCustoms
Joined Jul 4, 2019
7
Hello everyone,
First time posting.
I was trying to work out how to get a 3 pin 2 colour led to flash between the 2 colours at about 1Hz. Have found diagrams to do it using 2 different leds but these need 2 separate leds to work as they don’t share a cathode or anode. Also want to run it on 12volts.
Any help will be grateful.
dl324
Joined Mar 30, 2015
18,449
Welcome to AAC!
Draw a picture of the waveforms you want so we don't waste time designing something you don't want.
danadak
Joined Mar 10, 2018
4,057
https://startingelectronics.org/beginners/circuits/two-colour-LED-flasher/
A possibility.
You can do this with one chip, an ATTINY85, if you work with processors.
power would have to come from a regulator. Using mBlock graphical programming tool -
555 timer approaches -
https://electronics.stackexchange.com/questions/251867/how-to-alternate-2-led-strings-using-555-ic
https://forum.allaboutcircuits.com/threads/555-timer-alternating-blinking-led-circuit-issue.45180/
http://solderpad.com/psd/railway-crossing-lights/
Regards, Dana.
SanctuCaryCustoms
Joined Jul 4, 2019
7
Welcome to AAC!
I just want one colour on for a second and then the other colour on for a second and back to the start. I found how to do it using a 555 timer chip but that uses a switching polarity common.
SanctuCaryCustoms
Joined Jul 4, 2019
7
Thanks for the reply. I think I’ll give the second one down a try. I didn’t think about using the 555 timer unit to control a pair of transistors
dl324
Joined Mar 30, 2015
18,449
You can do it with a 555 timer and one transistor:
You can get approximate component values using this graph:
