Flash memory not programmed
Status
Not open for further replies.
pooya_b
Joined Feb 25, 2021
59
hi
I want to program W25Q64JVS flash memory but it shows me the following error.
'1': Reading status register contents...
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0011 1100 1110 1100
INFO:iMPACT:2492 - '1': Completed downloading core to device.
'1': IDCODE is 'ef4017' (in hex).
'1': ID Check passed.
'1': Erasing Device.
'1': Using Sector Erase.
'1': Erasing non-volatile quad-enable bit...
'1': Programming Flash.
'1': Reading device contents...
done.
'1': Verification completed.
'1':programming in x1 mode.
W25Q64BV Status Register Contents = 0x0200.
QUAD ENABLE : 1
STATUS REGISTER PROTECT 1 : 0
STATUS REGISTER PROTECT 0 : 0
SECTOR PROTECT : 0
TOP/BOTTOM PROTECT : 0
BLOCK PROTECT BIT 2 : 0
BLOCK PROTECT BIT 1 : 0
BLOCK PROTECT BIT 0 : 0
'1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and mode settings.
INFO:iMPACT - '1': Flash was not programmed successfully.
PROGRESS_END - End Operation.
Elapsed time = 76 sec
I designed this board myself and I will put some pictures of the flash memory connection for you.
In this section, you will see the settings that I made for programming.
Deleted member 115935
Joined Dec 31, 1969
This looks like the Xilinx Tool chain
Try the xilinx forum, they are very active and knowledgeable
pooya_b
Joined Feb 25, 2021
59
I am not sure about which link you are talking - if about schematic.pdf I attache this file to post.
Hello
No, I mean version 14.1 of xilinx ise software.
I can not download it. Due to the conditions of my country, I am not allowed to download from the site.
FlyingDutch
Joined Mar 16, 2021
84
what OS Linux or Windows? Are you sure that version number is 14.1? I can download it for you and give link on Google disk, but I don't know if it is not against this forum rules?
Best Regards
pooya_b
Joined Feb 25, 2021
59
Best Regards
Windows
Thank you very much for your kindness. Someone suggested try version 14.1 and get the answer.
I do not know if it is against the law or not.
Joined Dec 31, 1969
Hello
@pooya_b
Can I highlight that its a criminal offence to supply Xilinx software to a destination on the US restricted list.
It seems that you are on that list ,
as such, it would be illegal for anyone here to share you the software.
https://www.xilinx.com/support/answers/44043.html
Status
