VERY IMPORTANT TO ME READ THIS AND GIVE ADVICE yes i test reed switch but i think reed relay is more practical than reed switch>>hi,
You could consider a 'Reed micro switch' connected across the button contacts.
Like this type, use a small magnet fastened to a string pull off loop.
Update:
E
https://cpc.farnell.com/hamlin/mdcg...PING&s_kwcid=AL!5616!3!490691434307!!!network}!371789919038!&gclid=Cj0KCQiA4L2BBhCvARIsAO0SBda5Uv61tCbRqcH-bu1EL-f3shAcifDem_hoF5Y3dF-hqBBguOzkPO4aAsikEALw_wcB
YES I WILL TRY THISYou will need to isolate the phone from the circuit.
This is a simple 2 second timer using a relay to activate the phone.
Standby current is only 9 micro amps
Another version using an opto isolator to activate the phone
can you explain little more , i never seen a piano spring yetYou are all jumping to solutions!
Let us first analyze the problem: How to press the "1" button on a cellphone when a tripwire breaks.
What is the simplest solution?
My suggestion is this:
The piano wire spring is simply a piece of springy steel wire. One end of it is bent into a loop to attach the wire to. The other end is stuck into a firm base (block of wood?). The phone is positioned on the base with the piano wire almost touching the "1" key. The thin wire attached to the loop is connected to the trip wire which is pulled tight to move the piano wire away from the phone. When the wire breaks, the piano wire will spring back and strike the key on the phone.can you explain little more , i never seen a piano spring yet
I am an electronics engineer, but I am also a problem solver. Using electronics is not always the best way to solve a problem.
This solution does not need a power source. It does not contain a lot of components that could fail. As long as the phone is protected in a plastic bag, the normal environment will not interfere with its operation. A simple solution is usually the most reliable.
PLEASE READ THE BELLOW BY FOLLOWING THIS IDEAThe piano wire spring is simply a piece of springy steel wire. One end of it is bent into a loop to attach the wire to. The other end is stuck into a firm base (block of wood?). The phone is positioned on the base with the piano wire almost touching the "1" key. The thin wire attached to the loop is connected to the trip wire which is pulled tight to move the piano wire away from the phone. When the wire breaks, the piano wire will spring back and strike the key on the phone.
i am going to try this two diagrams , and i will come back with field testing reportsYou will need to isolate the phone from the circuit.
Should I need to add another 9v battery for each breaker loop ?, but I wanted to add low power consumption good LED on the phone side : when I reach the site at night how can I easily identify the device floating at water with fishing lineThe 4N25 is a 6 pin chip I just drew it as needed. I actually used P2501 optocoupler, either one is fine.
The break loops will not work wired in parallel as shown.
They would need to be wired in series but that doesn't work either as the first break will render the rest of the loops inoperative.
Adding additional loops will increase circuit complexity, especially adding the LEDs the are somehow going to be motion activated?
Not saying it can't be done using analog circuitry but this project is starting to scream digital.
No. One battery will suffice for as many loops as needed.Should I need to add another 9v battery for each breaker loop ?
No problem, just need details about LEDs you want to use.I need the LED to be Flash, when the phone rings by giving call into this phone LED should flash until the call ends
YES ,THANKS FOR VALUEABLE REPLIES, And I adding one more question about soldering 9v line and ground terminal for each ends please see attachment I mentioned details in it. and about LED,No. One battery will suffice for as many loops as needed.
Another version using only one 2N7000.
Ok butAll the RED 9V points are connected together.
All the ground symbols indicate a common connection.
Members please understandNo, no, no, NO! - this has already gone way off in a bad direction I think, some others have said this too.
This is not (yet) an electronics question or project but a security question, I really think you've put the cart before horse here.
It seems that people are gaining access to something or someplace and you want be aware when this happen as a means of preventing theft.
I'd like to hear more about that, where is this, is it private land? is it some unmanned "fishing machine" is it just a local river where you leave the line out and go wandering about, returning an hour later? All of this information and more is important if I'm to offer any ideas.
Yes that is very feasible. I have a circuit for that I can post here shortly.*can I stick a small VIBRATION sensor on phone rear side to activate a relay and Turn ON the LED flash light?
SorryPurchase in US $ in not economical for meYes that is very feasible. I have a circuit for that I can post here shortly.
Here's one suggestion for the high power LED from superbrightleds.com
Current draw is only 130 ma at 12 volts or 100 ma at 9 volts.
If you can't get this part then show me what you have access to and will design accordingly.
What kind of batteries do you have to power the LED assembly.
https://www.superbrightleds.com/mor...led-disc-15w-equivalent-130-lumens/1634/3847/
Read below
1) LED:: LINK > https://t.ly/C8KG at this time I am adding 1 LED but I need 5 LED diagram
2) BATTERY 3000mAh :: LINK> https://t.ly/FGCf Can this battery affordable for powering up 3.7 volt phone and 12v 10W White High Power LED For 7 day - if no breaking of the loop means battery will not loos its charge?
3) Power regulator for phone in required yes? 12v to 5v how can we do that without purchasing regulator or a converter board I have phone's old charger module can I use that board.
4) very important in project;; SOLAR::
LINK > t.ly/4qVK
12V 100 mA - Solar Panel is good for this project ? Please add and mark it's circuit as marked as duplicate loop circuit at previous reply (may be I add this later)
but we have to make sure on battery charging at day time and discharging at night time so please add needful
a 5mm Photocell Photoresistor LDR Light Sensor https://t.ly/4VQu This also help to ON and OFF the charging system to Charge and discharge battery automatically?
Yes suggestion is perfect but total shipping charges exceeds my project budget 73$=5288 Indian rupees so just adding links for materials only it's totally costs 27$ I JUST ORDERING PARTS FROM ONLINE INSIDE OF MY CONTRY SHIPPING CHARGES ARE NILL OR VERY LOW
Consider the part's technical feasibility and give advice...
ALL LINKS ARE VERY LONG DUE TO THIS I SHORTENED THE LINKS
by Don Wilcher
