Firmware read
Papabravo
Joined Feb 24, 2006
19,300
It looks like U5 - the Atmel chip.
You're going to have to create a schematic diagram to have any clue how to access the firmware, provided the manufacturer forgot to set the LOCK bits when the part was programmed. There is a very low order of probability for your chances of being able to access the firmware.
MirJohn
Joined Jul 12, 2021
Thank you for the replay. Any suggestions where I can start from? I really need to try at least.
Papabravo
Joined Feb 24, 2006
19,300
Start with the processor U5. On the PCB trace all the connections to see where they go. Pay particular attention to the pins that would be used to read and write the firmware.
