Finding Push button connector
TalHad20
Joined Dec 27, 2023
Hi guys,
I'm trying to find connector that fit to 16mm push buttons, like in the picture.
I will be happy to buy the connector and the terminals and crimp them by my self, not to buy assembled cable.
Thanks in advance!
Irving
Joined Jan 30, 2016
5,195
Welcome to AAC!
It helps to put your location in your profile otherwise the information might be of little use to you.
Looks like the connectors come pre-wired, usually with the switch itself but Aliexpress has the connectors on their own...
TalHad20
Joined Dec 27, 2023
Hi Irving,
Thanks I'm happy to be here.
I'm trying to find only the connector and buy it from TE, samtec or other manufacture, because I want to make custom cable for push button switch.
Irving
Joined Jan 30, 2016
5,195
From my personal experience its unlikely they'll sell you a bare connector unless you're buying 1000s - they'll happily quote you for a custom assembly.
Ya’akov
Joined Jan 27, 2019
10,370
Welcome to AAC.
I think I would probably take the pigtail and terminate it is a 6 pin connector that I could get more easily then make cables from that connector to whatever it is you want on the other end.
