Finding Missing R3 in Combination Circuit
aeln269
Joined Oct 18, 2020
31
Hi everyone, im stuck on this problem for my homework. What ive done so far is R3 = RT - R1 - R2 - R4. Also, the current total is supposedly 10ma
35,271
Step 1: What is the current flowing through R1?
Step 2: What is the voltage across R1?
Step 3: What is the voltage across R4?
Step 4: What is the current flowing through R4?
Step 5: What is the current flowing through R3?
Step 6: What is the voltage across R3?
Step 7: What is the resistance of R3?
aeln269
Joined Oct 18, 2020
31
For #1, I= V/R right? Also because this is a parallel circuit, does that make all of the voltages the same? So is it also 10ma?
35,271
No. You cannot make that assumption until you work through it.
R1 is in parallel with R2.
What is the equivalent resistance of R1 and R2?
What is the voltage across R2?
aeln269
Joined Oct 18, 2020
31
Ok this is what I did.
because R1 and R2 are in parallel, I combined them to solve for R1R2
1/1000+1/1000
2/1000
1000/2
R1R2 = 500
Then I used ohms law V=IR
V=(10ma)(500)
V=0.01(500)
V=5
which applies for both because they are parallel?
Ramussons
Joined May 3, 2013
1,572
Maybe I should highlight my point.
From the values given in the figure, R3 cannot be determined.
The footnote is an addon.
...... Also, the current total is supposedly 10ma ....
