Finding a switch
wayneh
Joined Sep 9, 2010
18,104
I'm repairing an electric leaf blower for a friend. Its switch (off plus two speeds, SPTT) has poor contacts that cause the blower to cut in and out. Any thoughts where to find a replacement? I looked at Mouser and didn't have much luck. Is it worth even looking more? I mean, it has to have fairly specific dimensions to fit the housing in addition to its switching functions.
I've asked her if she would really mind if I hardwire it to full on and just lose the switch. No reply yet!
JoeJester
Joined Apr 26, 2005
4,390
I would search for the part number that you see on that switch. Can you pull the red top off to see how to remove the switch from the plastic casing?
AlbertHall
Joined Jun 4, 2014
12,625
Bend back the metal clips that hold the contact plate and see what has happened inside. It may be possible to clean or re-tension (as appropriate) and restore the switch function. Nothing to lose.
wayneh
Joined Sep 9, 2010
18,104
I'll go after it with my Dremel to see if I can lift a number. I tried for a while to pry off the red cap but I was afraid it would break. I can't see how they could build it without that being removable, but it didn't budge.
It's not a name brand blower - just cheap chinese crap I think. Noting more than a blower motor in a plastic housing. I'm trying to get my friend to stop buying such stuff but it's a battle.
