I have Finder 60.12 relay (DTDP 220v 6-10A) (its data sheet). I want to use it to switch between two AC powers. I tested the relay, it work as intended. Its coil keeps energized when using 1st power source and when 1st power source turns off then the relay turns switch to 2nd power source.
I tested the relay for auto switching, it works as intended.
When, the coil of relay keeps energized, it slowly turns very hot, even not touchable with finger.
I also tried to remove the load and both power sources. I just powered the coil of relay. It still turns very hot slowly even not touchable after some time.
The load that I want to use with relay is only 1.5 A 220v max.
I also googled to solve the issue of its hot coil. I could not find.
Please guide me to stop it turning so much hot.
Thanks
Thanks
