Find y(t) form - in Fourier series
linhvn
Joined Nov 6, 2024
297
I have a question with this kind, when the problem gives the waveform like the picture below, how to determine x(t) form or y(t) form?
Papabravo
Joined Feb 24, 2006
22,111
The integrand has the same form in either case, but the diagrams allow you to change the limits of integration.
Papabravo
Joined Feb 24, 2006
22,111
I dont know what you mean.
Well, this is Homework Help. You're supposed to show us your best attempt to solve the problem. I've given you a hint, in a language you appear to understand, and I don't know what else you expect for absolutely no effort except asking a question. The answer to this question requires three things:
  1. Write the integral form of the Fourier Transform by combining the function x(t) or y(t) with the appropriate complex exponential
  2. Determine the appropriate limits of integration
  3. Do the integration and evaluate the result at the appropriate limits
WBahn
Joined Mar 31, 2012
33,199
It hard to tell exactly what you are asking about, but I think you are asking about how to express the waveform shown in the graph as an equation.
Plot the following function and you should be able to figure out everything you need.
y(t) = (t + 10) * [u(t+1) - u(t-2)] + (10 - t) * [u(t-2) - u(t-5)]
linhvn
Joined Nov 6, 2024
297
Can you tell me where you have that y(t) function?
WBahn
Joined Mar 31, 2012
33,199
The first step is to plot the given function. Say from -10 to +10.
If you can't do that, then we can work on that, but it also means you aren't yet ready to be working with Fourier transforms as you don't have the necessary basic concepts down.
