Find Vavg and Vrms
MrAl
Joined Jun 17, 2014
13,862
Hello there,
If the image was a little darker it would be easier for everyone to read.
Here is the same image enhanced by darkening a little and improving contrast. Much easier to read.
The handwriting is very neat though that's a plus :)
MrAl
Joined Jun 17, 2014
13,862
Form factor is the ratio of effective value to the average value.
I am confused while putting the value of T.
Quick note...
You know what RMS stands for right?
It stands for "the Root of the Mean of the Square". The proper math follows from that and i am not sure you are doing that yet.
WBahn
Joined Mar 31, 2012
33,324
Quick note...
Depending on where he is in the material, they may not have gotten there yet. The rms is not the definition of effective voltage, it followed from the definition of effective voltage.
MrAl
Joined Jun 17, 2014
13,862
I thought i saw in one of his papers that he was trying to calculate the RMS value but it did not look like the right calculation exactly. The writing was a little small though.
WBahn
Joined Mar 31, 2012
33,324
He might have. But was he calculating RMS, or what we calculating effective voltage based on the definition? Both will end up with the same setup result, so the only way to tell is from how the setup was done -- was it does by regurgitating an RMS formula or from setting up the problem to find the average power into a resistive load over one cycle?
I only looked at the first paper because once I find an error I generally figure there's not much point going any further until that issue is resolved. If I could get the TS to grasp that notion, he could save everyone, himself most especially, a lot of time pursuing work that is past repair.
MrAl
Joined Jun 17, 2014
13,862
Well i seem to recall seeing Vrms written down with a formula to the right that is not the whole calculation for an RMS value :)
WBahn
Joined Mar 31, 2012
33,324
I will absolutely take your word for it. Again, I didn't look at the work beyond the first major mistake as I would rather the TS learn to check their work incrementally instead of just blindly bashing through to an answer that was doomed to not be a solution from literally the second line of their work and for which just a bit of asking, "Does it make sense thus far," could have saved all that effort.
While certainly far from alone, this TS has a particularly troublesome habit of not realizing that the first step to get out of a hole you are digging is to stop digging.
Sajan Gurung
Joined Dec 20, 2018
33
In calculating Vavg, why are you only integrating the first part from 0 to pi/2?
First part is symmetrical function and average value is zero so for complete cycle in symmetrical so i only took half the time which is equal to pi/2, but i think since i only took half should i multiply it by 2 to get averwge for complete cycle? Did you mean that in second part aswell i should integrate from 0 to pi?
ericgibbs
Joined Jan 29, 2010
21,629
hi Sajan,
Forget the maths for a minute.
Just look at the graph in your first post, consider what the Vavg would be for a complete cycle, if the 2nd half of a full cycle is zero.
How can it be 'times 2' .????
E
