Find min/max limits on an opamp circuit
coolecho
Joined Oct 12, 2016
3
I need to determine the min and max output limits on the output of this opamp circuit. The resistors are 1%, and caps are 10%. VREF_A2D is accurate at 2.5 volts.
Thanks in advance,
coolecho
dl324
Joined Mar 30, 2015
18,404
Welcome to AAC!
You have a voltage follower with a divider on the input. Is this a trick question?
Does the reference voltage vary?
What is the purpose of R130?
coolecho
Joined Oct 12, 2016
3
Hi Dennis,
I'm not a designer so I don't know what R130 is for. The reference voltage VREF_A2D is very accurate 2.5 volts:
Thanks!
12,176
The intent of R130 is to improve the high frequency decoupling performance of C99. The actual effect is dependent on the load current characteristics of whatever the opamp is driving.
If the reference voltage is assumed to be theoretically perfect and the opamp input impedance is assumed to be theoretically infinite, then you can calculate the voltage at pin 3 for all 4 cases of the +/-1% resistors. To each of those four voltages, add and subtract the opamp's max input offset voltage error. Now you have 8 voltages. Somewhere in there are the max and min output voltages, and that probably is what is required.
If you want to go extra nuts, use the opamp's max input bias current to recalculate the four pin 3 node voltages...
