final embedded system in production
letItGo
Joined May 20, 2016
2
Dear,
I put a lot of effort to find out what I am going to ask but had not success. Besides this forum I searched through http://www.electro-tech-online.com/ and http://www.electronicspoint.com/ too but nothing.
What I try to find out?
I make my whole system with microcontroller works. Diods lighting, communication with outside world also works, motor spinning... But what I do not know is how to make 10 or 20 finished products from that one on my desk. Specific questions are these:
  1. How to program mC which is not on development board? For example I used development board STM32F3DISCOVERY and now I want to make few tens of products with mC which is on that board.
  2. Case making? How can I be sure that temperature, moisture or physical impact do not disturb my system? Please consider that I have not 3D printer.
  3. Power choosing and realization? Battery or public power system? Where to put on board? Why?
One more time I am sorry if I ask something which already exists here or ask something very stupid but I really did not succeed to find place where are described steps from system on desk to final product for production. Off course, I would like to do all of this on my own (if it is possible) without sending my schematic to some big company.
P.S. I put these questions on some other forums so if I get answer I will put it here also.
Thank you,
Best Regards
John P
Joined Oct 14, 2008
2,068
1 I can't help with that processor. A PIC processor would have an in-circuit programming mode, where you'd need to connect to 5 pins of the chip (2 of them are power and ground) and most development boards would have a matching connector to drive those pins. You do need to make sure that your design isn't using those programming pins for incompatible purposes, but there's usually a way to do this. This can lead you into a situation where the circuit board includes a connector which is used only once, but it may be the easiest way to deal with the requirement.
2 and 3 Depends on what you need. Is this product going to crawl across the ocean bed, or will it live indoors, safely placed on a shelf?
I have to say, your first message here has joined an AllAboutCircuits tradition where someone will come in and ask questions while guarding any information about the project as if it were a most precious secret.
Yes, I can see how that might happen.
letItGo
Joined May 20, 2016
2
First, thank you for fast response.
1.) I find some schmetics for making PIC programming tool. So, programming PIC is not a problem. Sorry I did not mention that. But programming ARM mC out of developing board is still the problem.
2.) 3.) It is not any secret about my project.I just supposed that someone would put here some general link about these issues. I try to make some wireless sensor network. Some mC will be put around with ZigBee modules watching some industrial processes and one mC will be something like server for all these modules. On tht one (server) I will put Linux with TCP/IP stack. That central mC is some kind of gateway to the Internet. So... All these mC should be properly secured from dust and physical impact. Wireless nodes should be battery driven but central is on public power network.
I am sorry if this description is enough. Should I give some more details? I will be complitely satisfied if you share with me some your experiance, how you make some final product. Based on that experience I can search deeper.
Thank you.
John P
Joined Oct 14, 2008
2,068
I work with little microcontrollers, not ARM-based stuff running Linux. Could a Raspberry Pi handle this interface?
You haven't been totally clear about the battery-powered sensor units. "All these mC should be properly secured from dust and physical impact" is the right thing to say, but does that mean you know how to do it, or you don't? It's not difficult to look up "sealed enclosure", anyway. But there are questions related to battery power. You need to consider:
Lifetime--must this be sealed up and run for years without service? If not, what's an acceptable service interval?
Access--if it's got to be serviced, how difficult is it to get to the unit, and what can/must be done with it? Can it be taken away, or is it permanently installed?
Battery type--single use or rechargeable? Recharge via external connector, or must case be opened (environmental versus convenience issues)?
I think it would be good if the sensor units could monitor their own battery level, if they could transmit this data to the master unit. That might save on maintenance cost.
Once again, I think if you're asking for help, you should be providing this information at the start.
