You needed a simulator to tell you that? It is obvious upon inspection.See the difference
I believe @joeyd999 one turns ON harder
Naaah ! I had sometime off and I wanna show it to @AnalogKid.You needed a simulator to tell you that? It is obvious upon inspection.
Isn't is 11mV lower with R3. Without R3 base drive current is more causing more turn ON.If I read the drawings correctly, the output saturation voltage is *lower* by 400 uV with R3 in place.
ak
The collector will be connected to PIC Digital IN. So it's no biggie.Hello,
It is also odd that the simulator shows a negative voltage at the collector in saturation.
Bertus
Please explain ur diagram.View attachment 113686 (insane)
Please sum it out for me.you're absolutely right about this one - i made a multi-feature test as current signal - , voltage signal - switch , parallel AC line effect at at 1cm away , switch strobe - to show/include in simulation the relative influence to setup your "clear readout" -- your simulation switches ground through 50 feet to switch 50 feet back to BJT BASE - only the inductance of the cable smoothing the "kick to GND" -- (( "not helpful ... blah blah blaa" - ((indeed)) ))
I know, but installation is out of my hand. I will recommend that to the customer but I dunno know they will always comply.Ignoring all the stuff in this thread; Twisted pair shielded wire will go a long way, provided the shield is connected to ground at one end only.
Yes, the base drive current is greater without R3, but that does not automatically mean that the transistor is more "on". Which is more important to you, a lower saturation voltage, or lower efficiency plus more heat dissipated in the device plus lower long-term reliability? Removing R3 basically doubles the base current, but that is not always a good thing.Isn't is 11mV lower with R3. Without R3 base drive current is more causing more turn ON.
Plenum cables? Nope normal cablesIgnoring all the stuff in this thread; Twisted pair shielded wire will go a long way, provided the shield is connected to ground at one end only.
Again more confusing.http://www.allaboutcircuits.com/textbook/alternating-current/chpt-14/characteristic-impedance/
http://www.rfcafe.com/references/electrical/dielectric-constants-strengths.htm
+ my (insane) setup doesn't consider the wires running along metal trays as they do in some installations where the coupling between signal cables and power lines are restricted to 1m length (i guess) and would have some 1k greater effect e.g. 2+ mH instead of 2 µH
So ....to sum it up, Is your version better, concerning noise immunity and long term reliability ?Yes, the base drive current is greater without R3, but that does not automatically mean that the transistor is more "on". Which is more important to you, a lower saturation voltage, or lower efficiency plus more heat dissipated in the device plus lower long-term reliability? Removing R3 basically doubles the base current, but that is not always a good thing.
ak
T = R * C, where T is in seconds, R is in ohms and C is in Farads. So for the low-to-high transition on the PIC I/O line, it will be 0.47 seconds, and for the high-to-low transition it will be 1 millisecond.Are the values correct for a 500msec time constant ?
Another thought?View attachment 115530
I need around 500msec time constant to slow down the response during on and off.
I have a counter routine setup in program but once in a blue moon I am getting a glitch during a contact bounce simulation.
I believe I can eliminate this by adding a RC between the PIC digital input and the circuit.
From the calculator I am getting the values of R28 and the 10uf cap. I included R8 in to the calculation.
by Robert Keim
by Jake Hertz
by Duane Benson
