Feritte core coil for LM1812
ronsimpson
Joined Oct 7, 2019
4,833
Looks like the capacitor is 0.001uF or 1nF.
Frequency 200khz.
The inductor should be 600uH.
While researching this I see that you can adjust the capacitor value. The point is to have the LC to resonate at 200khz. Some people were using " CAN-1A901HM " which has a different value, then changing the C to compensate.
Can you get the IC now days? I don't think so.
rxlock2
Joined Feb 12, 2023
12
I think for L1 650μH is good. A similar Elektor circuit uses the same value. What worries me and I do not understand is L2.
Thanks for the replies
ericgibbs
Joined Jan 29, 2010
21,588
hi rx,
L2 is the transducer driver inductor, usually a step-up transformer.
L1 is the base oscillator inductor.
E
Added: For L2 note the over wound inductor/auto transformer symbol
debe
Joined Sep 21, 2010
1,419
Can you get the IC now days? I don't think so. Yes they are still avalable on E bay, at a higher price than what i paid back in the 80s. Some Furuno sounders used this ic.
rxlock2
Joined Feb 12, 2023
12
The circuit of Electronics Australia does not have a power-boosting transistor at the output like the Elektor. Maybe I'll add a transistor. As a converter I will use an old depth sounder that I have.
ericgibbs
Joined Jan 29, 2010
21,588
hi
L2 is a step up auto transformer, 2 turns and 44 turns on a RM10 core.
Enamelled copper wire 0.8mm or 1mm OD diameter.
Read the LM1812 PDF I posted for details.
E
