E-book Correction Feedback on Alternating Current (AC) textbook
kemokid
Joined Oct 9, 2020
Feedback on https://www.allaboutcircuits.com/textbook/alternating-current/
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-1/what-is-alternating-current-ac/
less turns -> fewer turns
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-1/ac-waveforms/
These musical designations have the wrong subscripts. It should be A_3 through C_5. See https://en.wikipedia.org/wiki/Scientific_pitch_notation
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-1/principles-of-radio/
"How is electricity and magnetism related to each other?" -> "How are electricity and magnetism related to each other?"
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-2/more-on-ac-polarity/
"Conventional battery polarity" diagram has the plus and minus signs in the wrong places.
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-3/inductor-quirks/
"unless its superconducting wire" -> "unless it's superconducting wire"
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-4/series-resistor-capacitor-circuits/
In the filled-out boxes, 68.623 should be 68.623m for clarity.
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-4/parallel-resistor-capacitor-circuits/
Should have a completely filled out box just to bring students all the way through. Should be total Z of 4.9135 angle -10.675 degree, aka 4.8285 - j0.9102
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-5/review-of-r-x-and-z/
Second diagram: nit -> not
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-5/series-parallel-r-l-and-c/
In the first table, the column headings should be C_1, L, C_2, and R
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-6/electric-pendulum/
There's an extra diagram in here that doesn't belong (duplication of the first one).
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-6/q-and-bandwidth-resonant-circuit/
minumum -> minimum
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-9/mutual-inductance-and-basic-operation/
"it is symbolized by the capital letter “M” rather than the letter “L”:" – was there meant to be an equation here? Or an image of the letter M?
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-9/special-transformers-applications/
"If L changes in inductance, ZL will correspondingly change, thus changing the circuit current." ZL should be subscripted: Z_L
"Out of phase DC control windings allow symmetrical of control AC." -> "Out of phase DC control windings allow symmetrical control of AC."
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-9/practical-considerations-transformers/
kVA.kVA. -> kVA.
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-10/single-phase-power-systems/
gage -> gauge
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-10/three-phase-power-systems/
its carrying current -> it's carrying current
SPICE input and output needs to be formatted across multiple lines
each set spaced 120o apart -> each set spaced 120° apart
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-12/ac-voltmeters-ammeters/
Second diagram, the arrows on the bottom of the circuit should be switched: black going left, gray going right.
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-12/ac-instrumentation-transducers/
"can be constructed for limited motion of 360° (full-circle) motion" – a little unclear, seems like "of" might be a typo of "or". So: "can only be constructed for a portion of 360° (full-circle) motion"
The diagram at the beginning of the "Differential Capacitive Transducer Bridge" section appears twice in a row.
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-13/introduction-ac-motors/
Br in "Br due to hysteresis remains" should be B_R (B with a subscripted uppercase R) with a comma following
Same for "-Hc"
"Steinmetz’s Laws of hysteresis" prob should be "Steinmetz’s Law of Hysteresis" or "Steinmetz’s law of hysteresis"
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-13/synchronous-motors/
a few percents -> a few percent
"Though, the synchronous motor is more complex." - should be incorporated into the previous sentence
conversely, use -> and conversely, to use
The AC Motors chapter has a different voice from everything else, is harder to understand, and seems like it was written by someone who knows English well, but is not a native speaker.
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-14/characteristic-impedance/
(Z0) - zero should be subscripted
In last diagram, "impedance" is misspelled and unnecessarily capitalized
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-14/finite-length-transmission-lines/
The first diagram is labeled "Reflected wave." Prob not the best caption?
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-14/long-and-short-transmission-lines/
90o -> 90°
