Fast Recovery Diode Simulation
TC9
Joined Dec 14, 2020
Hi i am required to do a simulation to show the turn off and turn on characteristics regarding BYT12P-1000. I was simulating it with the PSpice. However, i can't seems to get the similar results from the datasheet. Attached below is the schematic and the schematic from datasheet.Capture.PNGCapture1.PNGCapture2.PNG
38,749
You need a switching voltage applied to the transistor input, to switch the transistor.
Your circuit just shows a DC condition.
Show the results of your simulation.
TC9
Joined Dec 14, 2020
Results.PNGThanks for the reply. Will try to add a switching voltage... And here is the result from the schematic above.
