Fast and accurate phase measurement.
Richardgr
Joined Jun 12, 2017
6
I have maybe an unusual question, hope there are someone out there that can point me
inn the right direction.
I have put together a new type of phase sensor, that turns out to be very fast and accurate.
It measures phase differences of a few femtoseconds between high frequency signals.
Heres some numbers from a test:
signal frequency: 20Mhz, measurement accuracy: 0,00003deg, measuring time: 1ms.
Are there any practical uses for a sensor like this?
Richard
BR-549
Joined Sep 22, 2013
4,931
1 ms. That means you can measure the phase difference 1000 times a sec. So I guess it would be ok for applications that don't change phase faster than that.
GopherT
Joined Nov 23, 2012
8,009
Richard
So, restating your specification, you are measuring two signals pass 20,000 cycles before you can tell they are 0.00003 degrees out of phase.
Do you have a way to determine each signal is consistent within 0.00003 degrees during that 1mSec?
Richardgr
Joined Jun 12, 2017
6
The sensor assumes that the signals are consistent during the measuring time,
or else I wold only get an average readout of the phase angle during that time period.
To determine consistency I suppose several measurements can be done,
to detect if there is any variation.
