Fake security laser scanner
cmartinez
Joined Jan 17, 2007
8,794
You trying to build one of these?
On my list of things to try. It is a really tough project though
That thing is run by a galvanometer, and yes, it's a real hard thing to do. And no, my device will be monochromatic and the beam will be moved around slowly.
spinnaker
Joined Oct 29, 2009
7,830
I might buy one of these and open it, just to see what's inside and consider tweaking it to make it do what I want.
Thanks for posting!
Maybe start with one of those holiday laser displays? You can get them real cheap here. I have been thinking of buying one to see what makes them tick.
Bernard
Joined Aug 7, 2008
5,784
How many of these devices are you planning on ?
Do you have the steppers ? I made a sketch using a 23BB-H051-23, 7.5 deg., 6 wire, 5V which rotates
a 10 mm mirror, 45 deg. from vertical inside of a 3/4 X 5/8 in. plastic tube which is the mounting for the laser module. Again my scanner is down.
spinnaker
Joined Oct 29, 2009
7,830
Another thought is if you have a trashed scanner. They have mirrors in them. I have two mirrored bars sitting on my work bench right now. If I can just figure out how to cut them without breaking them.
