Fake car alarm blinking led
pete1986
Joined Oct 12, 2013
20
Just wanting to make a flashing led that blinks when you remove key from ignition using a transistor. I have it working just wanted to ask if anyone would look over it and see if its ok.greatly appriciate any help
AnalogKid
Joined Aug 1, 2013
12,142
If you are sure that the IGN signal goes to an open dircuit when the ignition is off (as opposed to some other load on that line pullint it to GND), then things look ok.
For cleaner switching action:
tie the emitter directly to the battery
Increase the base resistor to GND to 10K
Not that the LED will not blink. It will be on continuously when the IGN signal is floating.
ak
pete1986
Joined Oct 12, 2013
20
The led is one if them blinking ones you just give ut voltage and it flashes. Ign signal is connected to cigarette lighter power and when key is removed this 12v cigarette power turns off. Can the emitter handle 14v
dl324
Joined Mar 30, 2015
18,333
You can eliminate the resistor in series with the emitter. The base resistor could be a larger value to reduce battery drain by about 10mA. If that makes the LED too bright, you can increase the resistor in series with it.
Hymie
Joined Mar 30, 2018
1,347
You do not need any additional components, other than the flashing LED and 1kΩ resistor.
Connect the resistor to a permanent 12V, and connect the cathode of the LED to a switched 12V ignition circuit.
With the ignition on, both sides of the LED will be at 12V (LED off), once the ignition is switched off, the impedance of the ignition circuit will provide a sufficiently low impedance path to operate the LED flasher circuit.
A ¼ Watt resistor will be OK.
AnalogKid
Joined Aug 1, 2013
12,142
Certainly worth a try.
For protection against all of the nasty things in an automotive electrical system, consider placing a 12 V to 15 V zener diode directly across the LED, cathode to GND. The resistor will limit operating current to the LED and transient current through the zener.
ak
pete1986
Joined Oct 12, 2013
20
I was thinking in building a pcb board SMD style using 2n2907 transistor and 1206 resistors. wouldi need to change anything in my orignal design to make this transistor work?
