As the title says, I need to find an external rotor motor, preferably working at 480 VAC. Desired rpm would about 450, or 900 tops. Power of between 5 and 7 HP. The thing is that it has to be heavy duty, and able to sustain some impact (it's not for a vehicle application), or at least able to be mounted on heavy duty ball bearings that will withstand the harsh treatment. Max outside diameter would be about 16 inches, and the minimum desirable inside diameter about 8 inches.
I've already found a couple of suppliers, but they're focused on the automotive industry, and I'm not sure if such motors would be able to comply with the harsh requirements.
Here's looking at you, @MaxHeadRoom
