External interrupt RB0/INT not working on PIC16f627A
Ely Ondo Ekogha
Joined Sep 27, 2017
9
Hello Everyone
I'm having a problem with my external interrupt on RB0 which is not firing when I tested it physically but it works well when I simulate the project on PROTEUS 7.
Basically the PIC is connected to a 74C922 encoder with DA pin connected to RB0 to trigger the interrupt and read the key entered from a 4x4 keypad. I also implemented a heart bit on pin RB4 to check if the code is running smoothly in the loop which it does (tested and simulation), however for some reason I just can't understand why the interrupt is not firing when tested physically.
NB: I set a pull down 4k7 on RB0 and I read data on rising edge of interrupt signal, I'm using internal OSC at 4 MHz. Also I omitted on purpose other functionalities which are not really a concern.
Please find attached asm file and the code.
Thank you for your assistance!
Here is the code:
Code:
; TODO INSERT CONFIG CODE HERE USING CONFIG BITS GENERATOR
; PIC16F627A Configuration Bit Settings
; Assembly source line config statements
#include "p16f627a.inc"
; CONFIG
; __config 0xFF18
__CONFIG _FOSC_INTOSCIO & _WDTE_OFF & _PWRTE_OFF & _MCLRE_OFF & _BOREN_OFF & _LVP_OFF & _CPD_OFF & _CP_OFF
; TODO ADD INTERRUPTS HERE IF USED
INT_VECT CODE    0x0004
    bcf    06h,4
    movf    05h,0
    movwf    20h
    call    mask
    btfsc    21h,0; test for programming mode
    call    counter
    btfss    21h,0; test for programming mode
    call     t_start; test for * key
    bcf    0Bh,1; INTF cleared
    RETFIE
RES_VECT  CODE    0x0000            ; processor reset vector
    goto    top
MAIN_PROG CODE                 ; let linker place main program
top    movlw    07h
    movwf    1fh
    bsf        0Bh,7; GIE enabled
    bsf        0Bh,4; INTE enabled
    bsf        03h,5; Bank 1
    bsf        06h,0; RB0 as input
    bsf        01h,6; INTEDG enable rising signal
    movlw        .255
    movwf        05h; RA0 to RA7 as input
    bcf        06h,4;
    bcf        06h,5; warning signal
    bcf        06h,6; armed signal
    bcf        06h,7; detection signal
    bcf        03h,5; Bank 0
    bcf        06h,7; PIR detection switch
    clrf    20h; Data process reg
    clrf    21h; Programming process reg
start    bsf    06h,4
    btfsc    05h,4; Test PIR1 signal
    goto    fire
    btfsc    05h,6; Test PIR2 signal
    goto    fire
    btfsc    05h,7; Test PIR3 signal
    goto    fire
    goto    start
fire
    btfsc    21h,1; Test Alarm flag
    goto    warning
    goto    start
warning    bsf        06h,5
    bsf        21h,2; Emr exit bit
    goto    del_NoStck
run    bcf        06h,5
    bsf        06h,7; PIR ON signal
    goto    start
mask    movlw    0fh
    andwf    20h,1
    return
t_start    movlw    .12
    subwf    20h,0
    btfsc    03h,2; test Z bit
    call    prog
    return
prog    bsf        21h,0; Set for Programming mode
    clrf    22h; reset the counter
    return
counter        incf    22h,1
            call    k1
            call    k2
            call    k3
            call    k4
            return
k1            movlw    .1
            subwf    22h,0; test for count1
            btfsc    03h,2; test for Z bit
            call    set_k1
            return
set_k1        movf    20h,0
            movwf    23h
            return
k2            movlw    .2
            subwf    22h,0; test for count2
            call    set_k2
            return
set_k2        movf    20h,0
            movwf    24h
            return
k3            movlw    .3
            subwf    22h,0; test for count3
            call    set_k3
            return
set_k3        movf    20h,0
            movwf    25h
            return
k4            movlw    .4
            subwf    22h,0; test for count4
            call    set_k4
            return
set_k4        movf    20h,0
            movwf    26h
            call    trig
            return
trig        bcf        21h,0; clear programming mode
            call    t_k1
            btfss    03h,2
            return
            call    t_k2
            btfss    03h,2
            return
            call    t_k3
            btfss    03h,2
            return
            call    t_k4
            btfss    03h,2
            return
            call    ok; Correct code arm/disarm device
            movlw    .2
            xorwf    21h,1; Toogle bit 21h,1
            return
ok            call    bipping
            btfss    21h,1; Test for alarm flag
            call    trig_on
            nop
            btfsc    21h,1; Test for alarm flag
            call    trig_off
            nop
            return
trig_on        call    delay_10s
            bsf        06h,6; Arm signal
            return
trig_off    bcf        21h,2; Emr bit exit del_Stck
            bcf        06h,6; disarm signal
            bcf        06h,7; PIR switch OFF
            return
bipping        bsf        06h,5
            call    delay_300ms
            bcf        06h,5
            call    delay_300ms
            bsf        06h,5
            call    delay_300ms
            bcf        06h,5
            call    delay_300ms
            bsf        06h,5
            call    delay_300ms
            bcf        06h,5
            call    delay_300ms
            clrf    36h
            clrf    37h
            clrf    38h
            return
t_k1        movlw    .0
            subwf    23h,1
            return
t_k2        movlw    .1
            subwf    24h,1
            return
t_k3        movlw    .2
            subwf    25h,1
            return
t_k4        movlw    .3
            subwf    26h,1
            return
delay_10s    movlw    .210
            movwf    27h
loop3        movlw    .200
            movwf    28h
loop2        movlw    .78
            movwf    29h
loop1        decfsz    29h,1
            goto    loop1
            decfsz    28h,1
            goto    loop2
            decfsz    27h,1
            goto    loop3
            return
delay_300ms    movlw    .150;
            movwf    30h;
loop6        movlw    .200
            movwf    31h
loop5        movlw    .2
            movwf    32h
loop4        decfsz    32h,1
            goto    loop4
            decfsz    31h,1
            goto    loop5
            decfsz    30h,1
            goto    loop6
            return
delay_1s    movlw    .201
            movwf    33h
loop9        movlw    .27
            movwf    34h
loop8        movlw    .60
            movwf    35h
loop7        decfsz    35h,1
            goto    loop7
            decfsz    34h,1
            goto    loop8
            decfsz    33h,1
            goto    loop9
            return
del_NoStck    movlw    .210
            movwf    36h
loop12        movlw    .200
            movwf    37h
loop11        movlw    .78
            movwf    38h
            btfss    21h,2; False trigger Emr exit
            goto    run
loop10        decfsz    38h,1
            goto    loop10
            decfsz    37h,1
            goto    loop11
            decfsz    36h,1
            goto    loop12
            goto    run
    END
sagor
Joined Mar 10, 2019
1,056
I'm not that good at raw assembly, but I do not see where you set the "OPTION_REG" (81H) to enable rising edge trigger (bit 6 = 1)
I'm also not sure about how much source current the DA pin on the 74C922 can supply, so maybe try a higher value pull down resistor on RB0. In fact, try it without a resistor as well...
Ely Ondo Ekogha
Joined Sep 27, 2017
9
The attached file
Thank you for your reply.
I tried removing the pull down resistor or put a higher resistance (10KOhms) but It's still not working. On line 68 of the script, I set the rising edge of the interrupt signal using "bsf 01h,6", even if I use "bsf 81h,6" it doesn't change the result.
I'm still looking for what's wrong, and I don't even think It's the code since PROTEUS 7 simulation works very well, I just wish I can be wrong.
Ely Ondo Ekogha
Joined Sep 27, 2017
9
Hi Ely,
Is the 74c922 , 3 State Control, /Output Enable set correctly in the circuit?
E
The output enable pin is connected to ground, the Key bounce pin is connected to 1 microfarad capacitor which is connected to ground, same thing for OSC pin 5 with a 10 nanofarad capacitor.
So yes, I believe I set the encoder accordingly.
joeyd999
Joined Jun 6, 2011
6,525
Slightly off topic:
a) which assembler are you using?
b) do they teach you in school to use file register addresses instead of names?
c) you should consider documenting your code a bit better. Excessive comments have no bearing on program execution, but allow other programmer to follow your code and logic, and make debugging easier.
ericgibbs
Joined Jan 29, 2010
21,643
Hi Ely,
Do you have Voltmeter to check the State of the Pin on the 16F627 you are using as the INT pin, RB0 when the Key is pressed ?
E
Ely Ondo Ekogha
Joined Sep 27, 2017
9
Slightly off topic:
a) I'm using assembly language for PIC16F62x , you can also check the datasheet for it. However if you meant which compiler, it is MPASM v5.86, which I believe could be the latest.
b) I was taught assembly in 2013 at school and in fact whether we use file register names or addresses, it wasn't an issue for the lecturer. I personally prefer to use register address, it's faster to write when coding and because I know the architecture as well.
c) I will take note of your advise as well. Also please if you need explanations on some part of the code where there are no comments I can help.
I really want to get this write and I don't mind being wrong anywhere in my code, I need your direction.
Thank you.
Ely Ondo Ekogha
Joined Sep 27, 2017
9
Hi Ely,
E
Yes I do have a voltmeter, and beside I also connected a buzzer at that pin to make sure that I'm getting a signal. But even without the buzzer I put a LED to check, the result is the same.
The LED switches ON but the interrupt is not firing, same with the 5V buzzer.
Ely Ondo Ekogha
Joined Sep 27, 2017
9
Hi Ely,
Do you have a clear photo you could post, showing wiring, so that we can check it out?
E
Here it is
The IC on top is the 74C922 keypad encoder below it is the PIC26F627A.
The other IC on the left is a quad dual inputs OR gate IC 74LS32 which takes inputs from interrupt signal and RB5 (another functionality in the script) the output is connected to the buzzer.
Thank you
Mod: lightened and focussed your photo.E
sagor
Joined Mar 10, 2019
1,056
PIC is in upper right of picture. You have 2 wires to/from RB0. The 74C922 cannot supply enough current to turn on a buzzer, I think. Thus the buzzer will be loading down that line, preventing a proper rising edge...
Drive the buzzer with a different pin of the PIC, do not use the 74C922 DA output to drive a LED or buzzer.
Also a 74LS32 may not be able to supply much current to drive any buzzer (0.4mA maximum), but can sink more current. TTL logic is best designed for sinking current, not sourcing it. Use an inverting buffer (NOR like 74LS02) or similar and connect buzzer to Vdd (5V) and let the 74xx chip go low to trigger the buzzer (or LED). Also, the buzzer may draw more current than allowed by TTL limits, you have to check what the current draw of it is. Use a resistor to limit current. A LED should be fine but limit current to 8mA or less, that is the low signal level current limit of a 74LSxx chip.
sagor
Joined Mar 10, 2019
1,056
Just wondering, why not just use the PIC to decode the keypad with 4 column and 4 row signals (8 pins). Software could do the debounce...
Sensacell
Joined Jun 19, 2012
3,789
Have you inspected the actual interrupt flag bit status, for this specific interrupt source?
There are a lot of bits that have to be right for the interrupt to actually run, at least then you know where to look.
Dividing problems in two is the way to track it down: Either the interrupt is happening, but the routine is not getting run, or the interrupt is not being registered.
The other thing to check is the port pin setup, not in analog mode or set to output, etc.
Ely Ondo Ekogha
Joined Sep 27, 2017
9
Thank you very much for your suggestions, it worked.
I removed the OR gate IC and the buzzer, put a pull down 33K resistor on RB0 and it worked. As much as I'm happy about it, I'm now worried because this is only one part of the system which must be connected to another pic, and LCD. I'm afraid it will not work well, especially because of the LCD display(16x2 Hitachi), but I will try.
Thank you guys for your help, I believe I'll be back very soon with another problem.
Cheers!
sagor
Joined Mar 10, 2019
1,056
Cheers!
There is a problem with your picture, there is no current limiting resistor for the led! You must have a resistor on any led to limit the current through it and limit what the PIC is sending, else you risk burning something out. It seems you do not understand current limits of your devices, read up on it. Usually a 2k to 4.7k resistor is used in 5V circuits to limit LED currents.
Ely Ondo Ekogha
Joined Sep 27, 2017
9
This was just for demoing, in fact I don't use those LEDs in the project. I know that for this type of LED a resistor of 100 or 220 Ohms will suffice.
But also you're right because I don't know or I didn't bother to consider the current limits of the devices and what's provided by my power source.
