exporting schematics
radix
Joined Feb 4, 2009
3
Iḿ using LTspice in Wine, Linux.
Looking for method for exporting the image from asc-file to .pdf, .jpg or other format with high image-quality (usable in GIMP).
I found only ´ write tot wmf´or ´PrtScr´, with too poor image-quality for large schematics.
Any ideas ?
Radix
thatoneguy
Joined Feb 19, 2009
6,359
You can print to a PDF with Adobe Acrobat Full version, and I believe there is a GNU version out in alpha somewhere, as a XPS to PDF Converter, to be used with the "Microsoft XPS Writer" Printer Driver.
There is a $49 shareware program called PrintToPDF which works with any application, just like the Adobe driver.
I use the full Adobe, so haven't looked at what's available recently.
bertus
Joined Apr 5, 2008
22,948
The Topic Starter said that he uses LINUX.
Also in linux you can add a PDF printer, so print to the PDF printer and you will have your PDF output.
Greetings,
radix
Joined Feb 4, 2009
3
ThX for the suggestions.
The PDF-printer in Wine created only a .ps postscript-file, which could not be imported in OpenOffice.
We found :
» PS2PDF convert a PostScript file to a PDF file.
This works well in a command-line, returning a real .PDF
Radix.
