- Joined Jan 23, 2018
- 28,579
Using a step-down transformer is usually the most efficient scheme,but sometimes the most expensive choice. And only in a recent post did I see that the drop was from 5 volts to 1.5 volts, while earlier I saw comments about a "huge voltage drop", but no mention of what it would be. Unfortunately, it may be that the LM317 is not a good choice for a low supply voltage and lower output voltage. I have not seen any application where it had a supply voltage less than 12 volts. There may be a problem as the reason for that.
