expanding BW using feedback question
yef smith
Joined Aug 2, 2020
1,485
Hello,I have built the following two stage amplifier as shown bellow.
In open loop i get 63dB gain and BW about 3Khz.
when i tried to add a feedback resistor to lower the gain and increase the bandwidth as shown in the formula below i get no change at all.
two stage amplifier with feedback is shown in the end.
Where did i go wrong in implementing the feedback effect of feedback ressistor to lower the gain and increase the bandwidth?
Thanks.
38,932
Two ways:
First, the feedback is around two inverting stages, so the feedback would be positive, not negative (you want negative, note the (-) sign on the feedback to the summing junction).
Second, the ideal input voltage source has zero impedance, so there is no summing of the feedback, as the feedback signal is shorted to ground through the input source.
yef smith
Joined Aug 2, 2020
1,485
Hello crutschow, i have implemented your advice and got increased of BW from 3K to 30K as shown bellow.
Is there some alternative OPAMP i can use to increase much more my BW?(to 5MHz)
Thanks.
38,932
For 30db of gain at 5MHz you need a gain-bandwidth of at least 150MHz.
So look for op amps with 200MHz gain-bandwidth or more, such as the LTC6269.
Note that using resistors with a value such as 732.82 makes no practical sense.
Use the nearest 1% value (click the Select Resistor option when the resistor popup is open).
yef smith
Joined Aug 2, 2020
1,485
Hello Audioguru because i have double pole i get a section far away wherei got 180 degrees and 0db amp.
So at 20MHz i could get aucilations.
two question:
1. if i put an input signal at this area of 20MHzhow what problematic phenomena i would see in my sectrum analyzer /scope?
2.how do i add here a component so i will get another poler and elinimate this area where i have 180 degrees and 0db area
yef smith
Joined Aug 2, 2020
1,485
Hello cruthow,My asc simulation file is attached.
38,932
Below is the sim where I added C3 to give an added dominate pole, and reduced the values of R6, R7, C1, and C2.
The result is a smooth rolloff with no amplitude or phase anomalies.
At 20MHz the response is down about 11.5dB from the midband gain, which is what you should see on a spectrum analyzer.
Audioguru again
Joined Oct 21, 2019
6,826
Opamps in series with overall negative feedback are usually unstable and oscillate.
You have both opamps with a 500kHz lowpass filter that adds some phase shift to make even more instability.
Why use opamps for such high gain and high frequency?
yef smith
Joined Aug 2, 2020
1,485
Hello Audioguru,what is the meaning of oscilation in real life.
We have our 0db 180 at 20MHZ
how would i recognize an oscilation?
38,932
If the Bode plot shows no signs of instability, then use the transient analysis to apply a small, fast, input pulse (e.g. 100mV, 1µs) and look for excess ringing or overshoot on the leading and trailing edges of the output signal (example below, which shows an acceptable single overshoot).
Sometimes there can be a large-signal (transient) instability, even though the Bode plot looks okay.
