Wolframore
- Joined Jan 21, 2019
- 2,619
maybe Elon Musk can test it out in space...
The Quantum vacuum thruster was one of the ideas of how a EMDrive and Cannae Drive could work.Never thought I'd agree with you on this... but sadly, you're right. Some of us have a hard time letting go of dreams, even on the face of conclusive evidence.
And btw, I think I'm beginning to understand your photon rocket explanation, and the violation of conservation of energy in this case.
My mind's been wondering lately if it would be possible to build a device that could somehow sync with the virtual particles on the vacuum and use them to produce thrust.
Did I say that was worst of all? I may have take that back. In the paper by White et al, they also write that the Cannae Drive “is producing a force that is not attributable to any classical electromagnetic phenomenon and therefore is potentially demonstrating an interaction with the quantum vacuum virtual plasma.” That last bit stopped me. What’s a quantum vacuum virtual plasma? I’d never heard the term, so I dropped a note to Sean Carroll, a Caltech physicist whose work dives deeply into speculative realms of cosmology and quantum theory.
Carroll wrote back immediately, with a pointed message: “There is no such thing as a ‘quantum vacuum virtual plasma,’ so that should be a tip-off right there. There is a quantum vacuum, but it is nothing like a plasma. In particular, it does not have a rest frame, so there is nothing to push against, so you can’t use it for propulsion. The whole thing is just nonsense. They claim to measure an incredibly tiny effect that could very easily be just noise.” There is no theory to support the result, and there is no verified result to begin with.
Hello,That's how we make scientific progress but
If boxes in space could move efficiently by shaking the inside I'm pretty sure Mother Nature would ready be using the process in the short time the universe has existed.Hello,
That's still a lead in the wrong direction.
By claiming "You can not fool Mother Nature" you make the assumption that you already know *everything* about so called Mother Nature.
So you dont know if you are the fool or not because Mother Nature may still hold some surprises that you dont yet know about.
In other words, we need to look at this in a non biased way and that means leaving the door open for either "no it does not work" or "yes it does work" and there is absolutely NO WAY you can EVER predict this. The past shows that in abundance. We always seem to think we have the answer, but then the next scientist that steps up to the platform finds a different result that changes science in many ways.
Most scientists don't listen to crackpots but they do listen to scientifically valid areas of study that are strange, exotic or weird. String Theory is a good example that has lead to important theoretical progress.I agree if scientists listened to everyone saying it won’t work we would have no discoveries.
It is happening where you stand. The movement of the Earths core.If boxes in space could move efficiently by shaking the inside I'm pretty sure Mother Nature would ready be using the process in the short time the universe has existed.
You are arguing with someone that believes the climate isn't changing and sea levels aren't rising.Hello,
Google "solar sails".My mind's been wondering lately if it would be possible to build a device that could somehow sync with the virtual particles on the vacuum and use them to produce thrust.
It is good to talk about those two during discussions like this one, but i just feel that you are taking too strong of a stance on the ideas coming up. There are other ways to look at it too such as something new that may be discovered along the way even though its' not the original goal.If boxes in space could move efficiently by shaking the inside I'm pretty sure Mother Nature would ready be using the process in the short time the universe has existed.
That's not usually the case that any one discovery changes science in many ways in today's age. We don't know everything but we know a hell of a lot and nothing will change the experiential results that validate CoE and CoM on every scale we have tested it from the observable universe to the smallest subatomic particle. IF there is every a result that changes our view on this them it MUST still be compatible with current experimental evidence too so not much will change in the physical world.
And we really know nothing of the physics of deep space where this propulsion would be used. We don't even know, in the big picture of things the physics of what effects things on Earth.Maybe if we knew everything about the universe that would be different, but we dont yet.
I was not talking about solar wind (which decreases as the distance from the sun increases), but rather vacuum's virtual particles.Google "solar sails".
According to present-day understanding of what is called the vacuum state or the quantum vacuum, it is "by no means a simple empty space". According to quantum mechanics, the vacuum state is not truly empty but instead contains fleeting electromagnetic waves and particles that pop into and out of existence.
Many scientists were considered "crackpots"... this is where we get our stereotypeMost scientists don't listen to crackpots but they do listen to scientifically valid areas of study that are strange, exotic or weird. String Theory is a good example that has lead to important theoretical progress.
Yeah we've seen this happen so much you would think it should be the rule not an exception.Many scientists were considered "crackpots"... this is where we get our stereotype
including: Aristarchus, Gregor Mendel, Copernicus (and of course Galileo), Kepler, Doppler just to name a few... did you know the Wright Brothers were called the "Lying Brothers" in Scientific America...
Hi,I'm with NSA on one thing. He's mentioned many times before that whatever new discoveries we make, they will have to be compatible with what we already know. That is, new things should be built atop what has already been thoroughly proven and tested.
But on the other hand, there are things staring at us in the face that we cannot explain with our current theories. Dark matter for instance ... it's phenomena that relativity, quantum theory nor our working models of gravitation have been able to explain ... would the development of new physics be needed to describe and understand it?
A crackpot isn't someone with controversial ideas; a crackpot is someone who claims that they've discovered some "truth" (or proven some well-established theory as wrong), without sufficient ability to do so. A crackpot is someone who insists that Einstein was wrong, yet doesn't actually understand general relativity well enough for their claim to be taken seriously.Many scientists were considered "crackpots"... this is where we get our stereotype
As I understand it, dark matter is a theoretical stub, a placeholder for something missing from our gravitational balance sheet. We can see that *something* needs to account for the apparent extra mass in galaxies, and we think that this *something* doesn't interact with the electromagnetic field, but we don't know what it actually is. So we call it "dark matter" for now and agree to fill in the blanks later.Dark matter for instance ... it's phenomena that relativity, quantum theory nor our working models of gravitation have been able to explain ... would the development of new physics be needed to describe and understand it?
