Exam question on Ohm's law.
Mah_Student
Joined Oct 15, 2020
Will you please, I need help to understand the solution to this question:
The examiner say that the answer is 11 Volt. I don't know why. Please help. Thanks
35,276
We do not do your homework for you. Show us how you would tackle the problem.
What is the equivalent resistance between a and d?
What is the current flowing from a to d?
What is the current flowing from c to d?
Have you considered that there is possibly a typo error in the question?
WBahn
Joined Mar 31, 2012
33,311
Strictly speaking, the answer should be -11 V. Probably just a bit of sloppiness on the part of the person that wrote the question. Interpret it to be talking about the magnitude of the voltage differences between the mentioned points and you'll be fine.
Mah_Student
Joined Oct 15, 2020
Thanks for the replies.
I found the explanation:
The equivalent resistance in bc =R/2 and in cd = R/3.
Since the potential difference ib bc = 3 V, then the current intensity = 3/(R(2) = 6/R A.
The total equivalent resistance = R + (R/2) + (R/3) = 11R/6.
Then the potential difference between a and d =(6/R) . (11R/6) = 11 V.
Thanks very much.
Audioguru again
Joined Oct 21, 2019
6,826
Why doesn't the question say the resistor values?
Is the student supposed to guess that they are all the same?
This exam question is so simple that I did it without writing down anything.
Ian0
Joined Aug 7, 2020
13,306
Isn't it -3V? No-one said where the power supply was connected. It could quite feasibly be between b and c, and no-one said that a and d were connected to anything at all.
WBahn
Joined Mar 31, 2012
33,311
No need to guess -- the resistance of each resistor is R.
And, yes, for people that have experience just a bit beyond where a student would be that is taking this exam this question should be so simple that it can be done by inspection without writing anything down. So what? The question is targeted at people for whom that kind of reasoning is just beginning to come into existence.
WBahn
Joined Mar 31, 2012
33,311
It's 3 V because that is the given condition. If you get to question whether it is -3 V instead, then you can just as validly question whether it is -98.2 V instead. It is a GIVEN that it is 3 V.
As for where the power supply is connected, your observation is valid in strict terms, but immaterial in practical terms. Representing circuit fragments this way with the understanding that the only connections to the rest of the circuit occur at the dangling ends is a nearly universal convention. It would be impossible to communicate anything other than the simplest circuits if this were not the case and if we could not rely on the reader to interpret the circuit fragment accordingly.
35,276
When I first saw the question my brain registered "the potential difference between c and d".
Now why would any instructor write down "between c and b" unless he/she was looking for a negative answer?
That is why I assumed there was a typo error somewhere.
If "between c and d" was meant, none of the choices is correct.
If "between c and b" is correct, then the instructor's answer of 11V is incorrect.
The most likely explanation is that whoever set the exam copied a question from a previous exam and simply changed a letter and some numbers, demonstrating typical laziness.
