Error burning bootloader on atmega328p u
Insidcircuit.
Joined Oct 9, 2022
16
I recently bought a new computer, so I had to install Arduino again. As a start, to test if everything properly working or not, I was trying to program my UNO with Blink. But I am getting following Output:Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Uno"
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc1
DickCappels
Joined Aug 21, 2008
10,662
STK-500 programmers are so old, I just assume mine won't work anymore. Those old AT90S controllers had a pretty short data retention compared to the later versions.
If that turns out to be your problem, you might find a documentation package on avrfreaks.net that contains a copy of the firmware for the AT908535 on the board. It was there about 20 years ago when I last looked.
