Equivalent resistor of a simple circuit
Bardia_Sahami
Joined Apr 23, 2020
Hi. Anyone knows how to calculate the Req of this circuit? n tends to infinite. (Btw is there any sub forums for circuits only?)
Bardia_Sahami
Joined Apr 23, 2020
PS - the numbers you see are based on ohm. like the resistor with "3" means a 3 ohm-resistor. (Numbers are the resistance value based on ohm)
RBR1317
Joined Nov 13, 2010
715
...how to calculate the Req of this circuit? n tends to infinite.
While I don't know how to make an infinite series for this resistor network, it's simple enough to program a spreadsheet to find the equivalent resistance for any value of N. The network achieves its final value near 5 ohms at N=6, and won't vary from that value by more than a micro-ohm no matter how large N gets.
