EPS32 PCB design
MrSalts
Joined Apr 2, 2020
2,767
Is there any pcb layouts for this chip available ? I am specially looking for one with antenna etched on pcb.
thanks
Why not buy an ESP32 on a development board. They have castellated holes so you can solder thos boards to a carrier board if you want to integrate with other components. Designing an antenna can be a challenge and then you also have to worry (more) about stray emissions if you don't buy a module. Just $3.25
Ya’akov
Joined Jan 27, 2019
10,283
As @MrSalts says, the ESPxx breakout boards designed for surface mounting give you a lot of advantages over the bare modules. This includes FCC approval and very refined RF related layout.
So, the question is, why do you want to make your own PCB? Do you have some reason that precludes the use of the breakout board route? Many commercially produced devices use the surface mount devices to avoid the various pitfalls of RF related design.
If you still need to do reinvent the wheel for some reason, the ESP32 Hardware Design Guidelines has information about PCB layout. And a reference design including OCAD files can be found here.
