EPROM DATA in a I960 Microcontroller system
brettsrt
Joined May 9, 2019
50
Hi i’ve been out of the game for a long time and jumping back in now but i have a project i am working on that i need help with. I have a M27C4002 eprom that i got a bin(or hex) file from is there any way for me to make sense of this data or covert any of the system data back to code? any help or input would be greatly appreciated
Papabravo
Joined Feb 24, 2006
22,116
There were no microcontrollers in 1960. A computer required air conditioning and cable run through a sub floor. It is a long shot, but if you can dump the contents you might be able to disassemble the code if you try various alternatives.
brettsrt
Joined May 9, 2019
50
INTEL i960
joeyd999
Joined Jun 6, 2011
6,450
Wow. Blast from the past. I was writing for the I960 back in the early 90s.
If you can find a i960 disassembler, you can read the raw .asm.
But you will not be able to make sense of it. The original code was likely written in C.
There were some great for the time SCSI RAID cards with a I960 controller.
dl324
Joined Mar 30, 2015
18,453
Without knowing how the data was used, it would likely take a lot of guessing.
INTEL i960
You could have spelled the part number correctly in the first place. In electronics tends to be a precise discipline, the case of a letter can make a huge difference...
Papabravo
Joined Feb 24, 2006
22,116
Since the i960 had a wide data bus you're unlikely to find coherent code in a single part. The M27C4002 was 256KBx16 part
brettsrt
Joined May 9, 2019
50
i did it was a capital i so i suppose that was misleading
brettsrt
Joined May 9, 2019
50
The data in question on this single EPROM, i am after this data cause you can change this chip to change what program is run so to speak, i have other chips(programs) data to compare to not sure if that would help, would it be easier to looking at the whole system? or what way should i go about this
joeyd999
Joined Jun 6, 2011
6,450
This thread made me decide to take a stroll down i960 memory lane. I dug up a bunch of old work. Here is the memory controller code I wrote for a 22V10 PLD written in ABEL (anyone remember that?):
Code:
module mem
title 'SRAM & EPROM Controller for PDA I960 CPU PCB'
mem device 'p22v10';
@Dcset
declarations
  "clock
   pmclk                    pin 1;
      "plcc                 pin 2;
  "inputs
   be3, be2, be1, be0       pin 2,3,4,5;
      "plcc                 pin 3,4,5,6;
   wrrd, blast, ads         pin 6,7,8;
      "plcc                 pin 7,9,10;
   ramce, romce,logce       pin 9,10,13;
      "plcc                 pin 11,12,16;
   reset                    pin 11;
      "plcc                 pin 13;
  "outputs
   we3, we2, we1, we0       pin 23,22,21,20  istype 'com';
      "plcc                 pin 27,26,25,24  istype 'com';
   wr, ready, active        pin 18,17,16     istype 'reg,invert';
      "plcc                 pin 21,20,19     istype 'reg,invert';
   t0,t1                    pin 15,14        istype 'reg,invert';
      "plcc                 pin 18,17        istype 'reg,invert';
   rden                     pin 19           istype 'reg,invert';
      "plcc                 pin 23           istype 'reg,invert';
  "power
   gnd                      pin 12;
      "plcc                 pin 14;
   vcc                      pin 24;
      "plcc                 pin 28;
  x       = .x.;
  z       = .z.;
  c       = .c.;
  be      = [be3,be2,be1,be0];
  we      = [we3,we2,we1,we0];
  s       = [active, ready, t1, t0];
  idle    = [1,1,1,1]; "s15
  tw4     = [0,1,1,1]; "s7
  tw3     = [0,1,1,0]; "s6
  tw2     = [0,1,0,1]; "s5
  tw1     = [0,1,0,0]; "s4
  td      = [0,0,1,1]; "s3
  trw     = [0,0,0,1]; "s1
  u0      = [0,0,0,0];
  u2      = [0,0,1,0];
  u8      = [1,0,0,0];
  u9      = [1,0,0,1];
  u10     = [1,0,1,0];
  u11     = [1,0,1,1];
  u12     = [1,1,0,0];
  u13     = [1,1,0,1];
  u14     = [1,1,1,0];
equations
  s.clk    = pmclk;
  wr.clk   = pmclk;
  we       = !(!wr.fb & !be);
  ready.oe = !rden.fb;
  s.ar     = !reset;
  wr.ar    = !reset;
  rden.ar  = !reset;
state_diagram s
   state idle:   if (!ads)                    then idle with {wr:=1;
                                                              rden:=1;} else
                 if (!ramce & !wrrd)          then tw1  with {wr:=1;
                                                              rden:=0;} else
                 if (!ramce &  wrrd & !blast) then tw1  with {wr:=0;
                                                              rden:=0;} else
                 if (!ramce &  wrrd &  blast) then tw2  with {wr:=0;
                                                              rden:=0;} else
                 if (!romce)                  then tw2  with {wr:=1;
                                                              rden:=0;} else
                 if (!logce)                  then tw3  with {wr:=1;
                                                              rden:=0;} else
                                                   idle with {wr:=1;
                                                              rden:=1;}
   state tw4:    if (!ads)                    then idle with {wr:=1;
                                                              rden:=0;} else
                                                   tw3  with {wr:=1;
                                                              rden:=0;}
   state tw3:    if (!ads)                    then idle with {wr:=1;
                                                              rden:=0;} else
                 if ( wrrd  & blast)          then tw2  with {wr:=0;
                                                              rden:=0;} else
                 if ( wrrd  & !blast)         then tw1  with {wr:=0;
                                                              rden:=0;} else
                                                   tw2  with {wr:=1;
                                                              rden:=0;}
   state tw2:    if (!ads)                    then idle with {wr:=1;
                                                              rden:=0;} else
                 if ( wrrd)                   then tw1  with {wr:=0;
                                                              rden:=0;} else
                 if (!wrrd)                   then tw1  with {wr:=1;
                                                              rden:=0;} else
                                                   idle with {wr:=1;
                                                              rden:=0;}
   state tw1:    if (!ads)                    then idle with {wr:=1;
                                                              rden:=0;} else
                 if (!wrrd)                   then td   with {wr:=1;
                                                              rden:=0;} else
                 if ( wrrd & !blast)          then td   with {wr:=0;
                                                              rden:=0} else
                 if ( wrrd &  blast)          then td   with {wr:=1;
                                                              rden:=0} else
                                                   idle with {wr:=1;
                                                              rden:=0;}
   state td:     if (!ads)                    then idle with {wr:=1;
                                                              rden:=0;} else
                 if (!wrrd & blast & (!ramce # !romce))
                                                              rden:=0;} else
                 if (!wrrd & blast & !logce)  then tw4  with {wr:=1;
                                                              rden:=0;} else
                 if (!wrrd & !blast & !ramce) then idle with {wr:=1;
                                                              rden:=0;} else
                 if (!wrrd & !blast & (!romce # !logce))
                                              then trw  with {wr:=1;
                                                              rden:=0;} else
                 if ( wrrd &  blast)          then tw3  with {wr:=1;
                                                              rden:=0;} else
                 if ( wrrd & !blast)          then idle with {wr:=1;
                                                              rden:=0;} else
                                                   idle with {wr:=1;
                                                              rden:=0;}
   state trw:                                 goto idle with {wr:=1;
                                                              rden:=0;}
  "unused states -- go back to idle
   state u0:      goto idle;
   state u2:      goto idle;
   state u8:      goto idle;
   state u9:      goto idle;
   state u10:     goto idle;
   state u11:     goto idle;
   state u12:     goto idle;
   state u13:     goto idle;
   state u14:     goto idle;
test_vectors([reset,pmclk,ads,ramce,romce,logce,blast,wrrd,be3,be2,be1,be0] ->
                                          [active,ready,wr,we3,we2,we1,we0])
"               b
"               l w
"   r c a r r l a r b b b b    a r   b b b b
"   s l d a o o s r e e e e    c d w e e e e
"   t k s m m g t d 3 2 1 0    t y r 3 2 1 0
   [1,0,x,x,x,x,x,x,x,x,x,x]->[1,z,1,1,1,1,1];
   [1,c,1,1,1,1,1,x,x,x,x,x]->[1,z,1,1,1,1,1];
"Non burst read from RAM:
"               b
"               l w
"   r c a r r l a r b b b b    a r   w w w w
   [1,c,0,x,x,x,x,x,x,x,x,x]->[1,z,1,1,1,1,1]; "->Tw2 (2)
   [1,c,1,0,1,1,0,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw1 (3)
   [1,c,1,0,1,1,0,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Td  (4)
   [1,c,1,0,1,1,0,0,x,x,x,x]->[1,1,1,1,1,1,1]; "->Tr  (5)
   [1,c,x,1,1,1,x,x,x,x,x,x]->[1,z,1,1,1,1,1]; "->idle
"Non burst write to RAM
"               b
"               l w
   [1,c,1,0,1,1,0,1,0,0,0,0]->[0,1,0,0,0,0,0]; "->Tw1 (3)
   [1,c,1,0,1,1,0,1,0,0,0,0]->[0,0,0,0,0,0,0]; "->Td  (4)
   [1,c,1,0,1,1,0,1,0,0,0,0]->[1,1,1,1,1,1,1]; "->Tr  (5)
"Burst read from RAM
"               b
"               l w
   [1,c,1,0,1,1,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw1 (3)
   [1,c,1,0,1,1,1,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Td  (4)
   [1,c,1,0,1,1,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw3 (5)
   [1,c,1,0,1,1,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw2 (6)
   [1,c,1,0,1,1,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw1 (7)
   [1,c,1,0,1,1,1,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Td  (8)
   [1,c,1,0,1,1,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw3 (9)
   [1,c,1,0,1,1,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw2 (10)
   [1,c,1,0,1,1,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw1 (11)
   [1,c,1,0,1,1,1,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Td  (12)
   [1,c,1,0,1,1,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw3 (13)
   [1,c,1,0,1,1,0,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw2 (14)
   [1,c,1,0,1,1,0,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw1 (15)
   [1,c,1,0,1,1,0,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Td  (16)
   [1,c,1,0,1,1,0,0,x,x,x,x]->[1,1,1,1,1,1,1]; "->Tr  (17)
"Burst write to RAM
"               b
"               l w
   [1,c,0,x,x,x,x,x,x,x,x,x]->[1,z,1,1,1,1,1]; "->Tw3 (2)
   [1,c,1,0,1,1,1,1,0,0,0,0]->[0,1,0,0,0,0,0]; "->Tw2 (3)
   [1,c,1,0,1,1,1,1,0,0,0,0]->[0,1,0,0,0,0,0]; "->Tw1 (4)
   [1,c,1,0,1,1,1,1,0,0,0,0]->[0,0,1,1,1,1,1]; "->Td  (5)
   [1,c,1,0,1,1,1,1,0,0,0,0]->[0,1,1,1,1,1,1]; "->Tw3 (6)
   [1,c,1,0,1,1,1,1,0,0,0,0]->[0,1,0,0,0,0,0]; "->Tw2 (7)
   [1,c,1,0,1,1,1,1,0,0,0,0]->[0,1,0,0,0,0,0]; "->Tw1 (8)
   [1,c,1,0,1,1,1,1,0,0,0,0]->[0,0,1,1,1,1,1]; "->Td  (9)
   [1,c,1,0,1,1,1,1,0,0,0,0]->[0,1,1,1,1,1,1]; "->Tw3 (10)
   [1,c,1,0,1,1,1,1,0,0,0,0]->[0,1,0,0,0,0,0]; "->Tw2 (11)
   [1,c,1,0,1,1,1,1,0,0,0,0]->[0,1,0,0,0,0,0]; "->Tw1 (12)
   [1,c,1,0,1,1,1,1,0,0,0,0]->[0,0,1,1,1,1,1]; "->Td  (13)
   [1,c,1,0,1,1,1,1,0,0,0,0]->[0,1,1,1,1,1,1]; "->Tw3 (14)
   [1,c,1,0,1,1,0,1,0,0,0,0]->[0,1,0,0,0,0,0]; "->Tw1 (15)
   [1,c,1,0,1,1,0,1,0,0,0,0]->[0,0,0,0,0,0,0]; "->Td  (16)
   [1,c,1,0,1,1,0,1,0,0,0,0]->[1,1,1,1,1,1,1]; "->Tr  (17)
"Non-burst read from ROM
"               b
"               l w
   [1,c,1,1,0,1,0,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw2 (3)
   [1,c,1,1,0,1,0,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw1 (4)
   [1,c,1,1,0,1,0,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Td  (5)
   [1,c,1,1,0,1,0,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Tw  (6)
   [1,c,1,1,1,1,1,0,x,x,x,x]->[1,1,1,1,1,1,1]; "->Tr  (7)
"Burst read from ROM
"               b
"               l w
   [1,c,1,1,0,1,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw2 (3)
   [1,c,1,1,0,1,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw1 (4)
   [1,c,1,1,0,1,1,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Td  (5)
   [1,c,1,1,0,1,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw3 (6)
   [1,c,1,1,0,1,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw2 (7)
   [1,c,1,1,0,1,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw1 (8)
   [1,c,1,1,0,1,1,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Td  (9)
   [1,c,1,1,0,1,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw3 (0)
   [1,c,1,1,0,1,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw2 (11)
   [1,c,1,1,0,1,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw1 (12)
   [1,c,1,1,0,1,1,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Td  (13)
   [1,c,1,1,0,1,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw3 (14)
   [1,c,1,1,0,1,0,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw2 (15)
   [1,c,1,1,0,1,0,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw1 (16)
   [1,c,1,1,0,1,0,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Td  (17)
   [1,c,1,1,0,1,0,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Tw  (18)
   [1,c,1,1,1,1,1,0,x,x,x,x]->[1,1,1,1,1,1,1]; "->Tr  (19)
"Non-burst read from LOG ROM
"               b
"               l w
   [1,c,0,x,x,x,x,x,x,x,x,x]->[1,z,1,1,1,1,1]; "->Tw4 (2)
   [1,c,1,1,1,0,0,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw3 (3)
   [1,c,1,1,1,0,0,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw2 (4)
   [1,c,1,1,1,0,0,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw1 (5)
   [1,c,1,1,1,0,0,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Td  (6)
   [1,c,1,1,1,0,0,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Tw  (7)
   [1,c,1,1,1,1,1,0,x,x,x,x]->[1,1,1,1,1,1,1]; "->Tr  (8)
"Burst read from LOG ROM
"               b
"               l w
   [1,c,1,1,1,0,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw3 (3)
   [1,c,1,1,1,0,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw2 (4)
   [1,c,1,1,1,0,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw1 (5)
   [1,c,1,1,1,0,1,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Td  (6)
   [1,c,1,1,1,0,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw4 (7)
   [1,c,1,1,1,0,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw3 (8)
   [1,c,1,1,1,0,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw2 (9)
   [1,c,1,1,1,0,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw1 (10)
   [1,c,1,1,1,0,1,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Td  (11)
   [1,c,1,1,1,0,1,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw4 (12)
   [1,c,1,1,1,0,0,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw3 (14)
   [1,c,1,1,1,0,0,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw2 (15)
   [1,c,1,1,1,0,0,0,x,x,x,x]->[0,1,1,1,1,1,1]; "->Tw1 (16)
   [1,c,1,1,1,0,0,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Td  (17)
   [1,c,1,1,1,0,0,0,x,x,x,x]->[0,0,1,1,1,1,1]; "->Tw  (18)
end
Papabravo
Joined Feb 24, 2006
22,116
What I am saying is that if there was an instruction word of 32-bits, it might be spread across 2 parts. It is unlikely that half a word would be in the first 16 bits and the other half in the next 16 bits.
Papabravo
Joined Feb 24, 2006
22,116
Code:
module mem
@Dcset
declarations
  "clock
   pmclk                    pin 1;
      "plcc                 pin 2;
  "inputs
      "plcc                 pin 3,4,5,6;
      "plcc                 pin 7,9,10;
      "plcc                 pin 11,12,16;
   reset                    pin 11;
      "plcc                 pin 13;
  "outputs
  "power
   gnd                      pin 12;
      "plcc                 pin 14;
   vcc                      pin 24;
      "plcc                 pin 28;
  x       = .x.;
  z       = .z.;
  c       = .c.;
  td      = [0,0,1,1]; "s3
  u0      = [0,0,0,0];
  u2      = [0,0,1,0];
  u8      = [1,0,0,0];
  u9      = [1,0,0,1];
  u10     = [1,0,1,0];
  u11     = [1,0,1,1];
  u12     = [1,1,0,0];
  u13     = [1,1,0,1];
  u14     = [1,1,1,0];
equations
  s.clk    = pmclk;
  wr.clk   = pmclk;
  s.ar     = !reset;
  wr.ar    = !reset;
  rden.ar  = !reset;
state_diagram s
                                                              rden:=1;} else
                                                              rden:=0;} else
                                                              rden:=0;} else
                                                              rden:=0;} else
                                                              rden:=0;} else
                                                              rden:=0;} else
                                                   idle with {wr:=1;
                                                              rden:=1;}
                                                              rden:=0;} else
                                                   tw3  with {wr:=1;
                                                              rden:=0;}
                                                              rden:=0;} else
                                                              rden:=0;} else
                                                              rden:=0;} else
                                                   tw2  with {wr:=1;
                                                              rden:=0;}
                                                              rden:=0;} else
                                                              rden:=0;} else
                                                              rden:=0;} else
                                                   idle with {wr:=1;
                                                              rden:=0;}
                                                              rden:=0;} else
                                                              rden:=0;} else
                                                              rden:=0} else
                                                              rden:=0} else
                                                   idle with {wr:=1;
                                                              rden:=0;}
                                                              rden:=0;} else
                                                              rden:=0;} else
                                                              rden:=0;} else
                                                              rden:=0;} else
                                                              rden:=0;} else
                                                              rden:=0;} else
                                                              rden:=0;} else
                                                   idle with {wr:=1;
                                                              rden:=0;}
                                                              rden:=0;}
"               b
"               l w
"               b
"               l w
"               b
"               l w
"               b
"               l w
"Burst write to RAM
"               b
"               l w
"               b
"               l w
"               b
"               l w
"               b
"               l w
"               b
"               l w
end
Who could forget ABEL and the Data I/O programmer with the interchangeable heads.
brettsrt
Joined May 9, 2019
50
i see what your saying, is it possible that it only uses 16bit instead of 32bit for the word? the other chips on this board are a pair of M27C801 chips that are a changed in a pair (2 chips) and one M27C1001, which are 8 bit
Papabravo
Joined Feb 24, 2006
22,116
That's a lot of different nonvolatile chips making continued speculation extremely difficult. It is possible that the i960 had a rudimentary loader in one of the chips whose sole purpose was to load the data from another chip into RAM. Have a go at trying to decode it but probably a complete waste of time. I've seen serial NV FLASH chips used for this purpose among ADI DSP chips like TigerShark & Blackfin
brettsrt
Joined May 9, 2019
50
any tips on how to decode or what i can do? Can it be de-compiled or what are my options or type of software to do so? Again the data i am trying to modify is solely specific to the M27C4002 chip. any point in the right direction is greatly appreciated, i am totally in the dark on this one but am highly motivated to figure this out!
